查看: 1845|回复: 3
请教怎样输出某一个图层为一个新的dwg文件
发表于 2005-12-16 11:30:00 | 显示全部楼层 |阅读模式
是用LayerStateManager的export可以吗?
具体的命令应该怎么写?
谢谢!
发表于 2005-12-16 11:57:00 | 显示全部楼层
[分享]将一个图层上所有的对象另存为另一个图形
Wblock a layer into a new DWG named by the original DWG and layer name.
Code Sample   Public Function WBlockLay(strLayerName As String) 'For more than one LayerName in strLayName 'strLayName = "LayName1,Layname2,LayName3" Dim objlayer As AcadLayer Dim objSelSet As AcadSelectionSet Dim intType(0) As Integer Dim varData(0) As Variant Dim BlockedDWG As String On Error GoTo errControl
Set objSelSet = ThisDrawing.SelectionSets.Add("WBLOCKSET")
intType(0) = 8 varData(0) = strLayerName objSelSet.Select acSelectionSetAll, filtertype:=intType, filterdata:=varData 'You Need to add a backslash BlockedDWG = ThisDrawing.Path &
 楼主| 发表于 2005-12-16 14:35:00 | 显示全部楼层
呵呵,搞掂啦!
非常感谢!!
发表于 2016-11-3 14:54:54 | 显示全部楼层
程序还不完全,运行不了
GMT+8, 2025-7-16 06:30 , Processed in 0.166143 second(s), 24 queries , Gzip On.
