查看: 2966|回复: 2
[求助]
发表于 2005-12-17 22:09:00 | 显示全部楼层 |阅读模式
求助你好:我的程序在此:
Private Sub Command1_Click()
 On Error Resume Next
  Dim acadApp As AcadApplication
 Set acadApp = GetObject(, "AutoCAD.Application")
    acaApp.Command = script.exe
    If Err Then
        Err.Clear
      Set acadApp = CreateObject("AutoCAD.Application")
        If Err Then
            MsgBox Err.Description
            Exit Sub
        End If
    End If
Dim plineobj As Autocad.AcadLWPolyline
 Dim points(0 To 5) As Double
 points(0) = 1: points(1) = 1
 points(2) = 100: points(3) = 100
 points(4) = 200: points(5) = 200
 Set plineobj = acadApp.ActiveDocument.ModelSpace.AddlightweightLWPolyline(points)
 plineobj.Closed = ture
   ZoomExtents
 ZoomAll
acadApp.Visible = True
End Sub
谢谢你!总算有侠义之士了
发表于 2005-12-17 23:03:00 | 显示全部楼层
不好意思,不懂
 楼主| 发表于 2005-12-18 08:53:00 | 显示全部楼层
没关系了,共同学习,谢谢!
GMT+8, 2025-4-29 15:47 , Processed in 0.159387 second(s), 23 queries , Gzip On.
