[求助][1228]给线段编号编程方法
在使用vertexs 函数可以将线段顶点编号产生
但若为若干的线段非多义线时该如何处理呢?
以及如何改写才可自动判断多义线顶点数量而自动产生编号呢?
![](source/plugin/imc_colorcode/images/loading.gif) - vertexs 函数
- (defun vertexs (ename / plist pp n)
- (setq obj (vlax-ename->vla-object ename))
- (setq plist (vlax-safearray->list
- (vlax-variant-value
- (vla-get-coordinates obj)
- (setq n 0)
- (repeat (/ (length plist) 2)
- (setq pp (append
- pp
- (list (list (nth n plist) (nth (1+ n) plist) ) ) )
- (setq n (+ n 2))
- pp
- 多义线顶点编号产生
- (defun c:ts ( / polygon pt1 pt2 pt3 pt4 pt5 pt6 ptlist str1 str2 str3
- str4 str5 str6)
- (setq ptlist (vertexs (car (setq polygon (entsel "\n请点选物件:")))))
- (setq pt1 (nth 0 ptlist)
- pt2 (nth 1 ptlist)
- pt3 (nth 2 ptlist)
- pt4 (nth 3 ptlist)
- pt5 (nth 4 ptlist)
- pt6 (nth 5 ptlist)
- (setq str1 (strcat "PT1:X=" (rtos (car pt1) 2 4) ", Y=" (rtos (cadr
- pt1) 2 4)))
- (setq str2 (strcat "PT2:X=" (rtos (car pt2) 2 4) ", Y=" (rtos (cadr
- pt2) 2 4)))
- (setq str3 (strcat "PT3:X=" (rtos (car pt3) 2 4) ", Y=" (rtos (cadr
- pt3) 2 4)))
- (setq str4 (strcat "PT4:X=" (rtos (car pt4) 2 4) ", Y=" (rtos (cadr
- pt4) 2 4)))
- (setq str5 (strcat "PT5:X=" (rtos (car pt5) 2 4) ", Y=" (rtos (cadr
- pt5) 2 4)))
- (setq str6 (strcat "PT6:X=" (rtos (car pt6) 2 4) ", Y=" (rtos (cadr
- pt6) 2 4)))
- (command "text" "j" "tl" pt1 "3" "0" str1)
- (command "text" "j" "tl" pt2 "3" "0" str2)
- (command "text" "j" "tl" pt3 "3" "0" str3)
- (command "text" "j" "tl" pt4 "3" "0" str4)
- (command "text" "j" "tl" pt5 "3" "0" str5)
- (command "text" "j" "tl" pt6 "3" "0" str6)
- (prin1))
- (setq n 0)
- (setq pp (append
- pp
- (setq n (+ n 2))
- pp
