各位帮主:请帮帮忙吧。这个问题困扰我好久了,为什么我在vb编程时将外面的边界线分为两段,他咋就填补上了那?并且填到内边界线里了?请看程序:
On Error Resume Next Dim acadApp As AcadApplication Dim acaddoc As AcadDocument Set acadApp = GetObject(, "AutoCAD.Application") ' acaApp.Command = script.exe If Err Then Err.Clear Set acadApp = CreateObject("AutoCAD.Application") Set acaddoc = acadApp.ActiveDocument acadApp.Visible = True If Err Then MsgBox Err.Description Exit Sub End If End If Dim hatchobj As AcadHatch Dim patternname As String Dim patterntype As Long Dim bassociativity As Boolean patterntype = 0 patternname = "ansi31" bassociativity = True Set hatchobj = acadApp.ActiveDocument.ModelSpace.AddHatch(0, "ansi31", True) Dim innerloop(0 To 0) As AcadEntity Dim outerloop(0 To 0) As AcadEntity Dim Plineobj As AcadLWPolyline Set acaddoc = acadApp.ActiveDocument Dim points(0 To 7) As Double points(0) = 10: points(1) = 10 points(2) = 30: points(3) = 50 points(4) = 70: points(5) = 20 Dim stp0(0 To 2) As Double Dim enp0(0 To 2) As Double stp0(0) = 70: stp0(1) = 20: enp0(2) = 0 enp0(0) = 10: enp0(1) = 10: enp0(2) = 0 ' Set plnObj = acadApp.ActiveDocument.ModelSpace.AddLine(stp0, enp0) ' points(6) = 10: points(7) = 10 Set innerloop(0) = acaddoc.ModelSpace.AddLightWeightPolyline(stp0, enp0) Dim centerpoint10(0 To 2) As Double Dim endpoint10 As Double Dim radius10 As Double centerpoint10(0) = 20: centerpoint10(1) = 20: centerpoint10(2) = 0# radius10 = 4 Set outerloop(0) = acadApp.ActiveDocument.ModelSpace.AddCircle(centerpoint10, radius10) hatchobj.AppendOuterLoop (outerloop) hatchobj.AppendInnerLoop (innerloop) hatchobj.Evaluate acadApp.ActiveDocument.Regen True ZoomExtents ZoomAll
在此先谢谢各位了  |
