查看: 1835|回复: 2
[LISP]实时钟表
发表于 2006-1-9 10:15:00 | 显示全部楼层 |阅读模式
原因:看到网友发了个钟表程序,只能从12:00开始计时,现作了点修改。
结果:可以随着系统时间来运行,看起来象真的表一样.
不足:死循环,退出时比较麻烦。
改进:希望各位提出改进措施。
发表于 2006-1-10 11:54:00 | 显示全部楼层
楼主的函数名和cad自己的命令重复了。呵呵
发表于 2006-1-11 16:47:00 | 显示全部楼层
;我写的时钟程序
;同样的问题,死循环,只能"ESC"强行退出,退出后osmode值为0
;请高手指点一下如何处理
;我试过自己定义出错程序,但是无效.退出循环属于中断不是出错!!!
(defun c:clock()
  (setvar "cmdecho" 0)
  (setq os (getvar "osmode"))
  (setvar "osmode" 0)
  (setq cen (getpoint "\n中心点:"))
  (setq rr (* (getdist cen "\n半径:") 2))
  (lsp_22a)
  (lsp_22b)
  (lsp_22c)
  (setvar "osmode" os)
(defun lsp_22a()
  (setvar "cecolor" "131")
  (command "donut" 0 (/ (* rr 43) 40) cen "")
  (setq pp_12 (polar cen (/ pi 2) (/ rr 2)))
  (setq pp_3 (polar cen 0 (/ rr 2)))
  (setq pp_6 (polar cen (* pi 1.5) (/ rr 2)))
  (setq pp_9 (polar cen pi (/ rr 2)))
  (setvar "cecolor" "2")
  (command "donut" 0 (/ rr 48) pp_12 "")
  (command "array" (entlast) "" "p" cen 60 360 "")
  (setvar "cecolor" "1")
  (command "donut" 0 (/ rr 24) pp_12 "")
  (command "array" (entlast) "" "p" cen 12 360 "")
  (setvar "cecolor" "7")
  (setq t1 (polar cen (/ pi -2) (* (/ rr 100) 4)))
  (setq t2 (polar cen (/ pi 2) (* (/ rr 20) 7)))
  (command "pline" t1 "W" 0 (/ rr 36) cen "w" (/ rr 36) 0 t2 "")
  (setq en3 (entlast))
  (setvar "cecolor" "3")
  (setq d1 (polar cen (/ pi -2) (* (/ rr 100) 6)))
  (setq d2 (polar cen (/ pi 2) (* (/ rr 20) 8)))
  (command "pline" d1 "W" 0 (/ rr 40) cen "w" (/ rr 40) 0 d2 "")
  (setq en1 (entlast))
  (setvar "cecolor" "5")
  (setq m1 (polar cen (/ pi -2) (* (/ rr 100) 7)))
  (setq m2 (polar cen (/ pi 2) (* (/ rr 20) 8.8)))
  (setq m3 (polar cen (/ pi -2) (* (/ rr 100) 1)))
  (command "pline" m1 "w" 0 0 m3 "a" "ce" cen "a" 180 "a" 180 "ce" cen "l" m2 "")
  (setq en2 (entlast))
  (setvar "cecolor" "bylayer")
  (setq ti (rtos (getvar "cdate") 2 6))
  (setq tt (substr ti 10 2))
  (setq dd (substr ti 12 2))
  (setq mm (substr ti 14 2))
  (command "rotate" en3 "" cen (* (atoi tt) -30))
  (command "rotate" en3 "" cen (* (atoi dd) -0.5))
  (command "rotate" en1 "" cen (* (atoi dd) -6))
  (command "rotate" en2 "" cen (* (atoi mm) -6))
(defun lsp_22b()
  (setq txt_1 (polar cen (/ pi -2) (/ rr 4)))
  (setq data (substr ti 1 8))
  (setvar "cecolor" "6")
  (command "text" "m" txt_1 (/ rr 24) 0 data)
(defun lsp_22c()
  (setq n 1)
  (while (= n 1)
    (setq ti1 (rtos (getvar "cdate") 2 6))
    (setq tt1 (substr ti1 10 2))
    (setq dd1 (substr ti1 12 2))
    (setq mm1 (substr ti1 14 2))
    (if (/= dd1 dd)
 (setq dd dd1)
 (command "rotate" en3 "" cen -0.1)
    (if (/= mm1 mm)
 (setq mm mm1)
 (command "rotate" en1 "" cen -0.1)
 (command "rotate" en2 "" cen -6)
(princ "\n\n…………〉〉时钟〈〈…………")
(prin1)
GMT+8, 2025-9-1 08:14 , Processed in 0.176726 second(s), 28 queries , Gzip On.
