查看: 2090|回复: 2
奉献一选择集程序(vba)
发表于 2006-1-12 18:48:00 | 显示全部楼层 |阅读模式
On Error Resume Next
 ' Delete the Selection Set if it Exists
 If Not IsNull(ThisDrawing.SelectionSets.Item("xxx")) Then
    Set sset = ThisDrawing.SelectionSets.Item("xxx")
    sset.Delete
 End If
    Set sset = ThisDrawing.SelectionSets.Add("xxx")
发表于 2006-1-12 21:03:00 | 显示全部楼层
抄的吧?
发表于 2006-1-12 21:40:00 | 显示全部楼层
这是明经通道原创,三行搞掂:
Function CreateSelectionSet(Optional SSetName As String = "mjtd") As AcadSelectionSet
    ThisDrawing.SelectionSets(SSetName).Delete
    Set CreateSelectionSet = ThisDrawing.SelectionSets.Add(SSetName)
End Function
GMT+8, 2025-8-31 11:32 , Processed in 0.215986 second(s), 23 queries , Gzip On.
