查看: 1956|回复: 3
[求助]如何得到两条多义线的交点
发表于 2006-1-15 11:47:00 | 显示全部楼层 |阅读模式
任意两条多义线,如何得到他们的交点.
或直接求两条多义线的面积(主要用于公路中填挖面积的计算)
 楼主| 发表于 2006-1-17 10:20:00 | 显示全部楼层
 Dim intPoints As Variant
    intPoints = lineobj.IntersectWith(circleobj, acExtendNone)
    ' Print all the intersection points
    Dim I As Integer, j As Integer, k As Integer
    Dim str As String
    If VarType(intPoints) <> vbEmpty Then
        For I = LBound(intPoints) To UBound(intPoints)
            str = "Intersection Point[" & k & "] is: " & intPoints(j) & "," & intPoints(j + 1) & "," & intPoints(j + 2)
            MsgBox str, , "IntersectWith Example"
            str = ""
            I = I + 2
            j = j + 3
            k = k + 1
        Next
    End If
发表于 2006-4-11 12:35:00 | 显示全部楼层
 2桉的方法好象不行,能否再更新一下,运行时会提示每二行的问题“此处需要物体”
本人也在找一个求多边形各顶点的方法,不知道可否赐教,多谢
发表于 2006-4-11 15:50:00 | 显示全部楼层
GMT+8, 2025-5-4 16:31 , Processed in 0.174436 second(s), 23 queries , Gzip On.
