 - Sub mm()
- On Error Resume Next
- Dim ssetObj As AcadSelectionSet
- Set ssetObj = ThisDrawing.SelectionSets.Add("SSET_OBJ")
- If Err Then
- Err.Clear
- Set ssetObj = ThisDrawing.SelectionSets("SSET_OBJ")
- End If
- On Error GoTo 0
- ' Add objects to a selection set by prompting user to select on the screen
- ' ssetObj.Clear
- ssetObj.Clear
- Dim FilterType(0) As Integer, FilterData(0) As Variant
- FilterType(0) = 0
- FilterData(0) = "CIRCLE"
- ssetObj.SelectOnScreen FilterType, FilterData
- sngSum = ssetObj.Count
- End Sub
