查看: 2167|回复: 9
一个十分方便的关闭层的小程序
发表于 2006-1-19 23:21:00 | 显示全部楼层 |阅读模式
(defun c:ff(/ pt ss w e l )
  (setq oer *error* *error* myerr)
  (setvar "cmdecho" 0)
  (setq ss (entsel "\n点取层中某一物体:"))
  (while ss
     (setq w (getvar "clayer"))
     (if (= (type ss) 'list)
         (setq e (entget (car ss)) L (cdr (assoc 8 e)))
         (if (eq l w) (command "layer" "off" l "y" "")
           (command "layer" "off" l "")
         (princ (strcat "    (" l "层已被关闭)"))
     (initget "U")
     (setq ss (entsel "\nU/<点取层中某一物体>:"))
     (if (eq ss "U") (command "u"))
  (setq *error* oer)
  (princ "\n
发表于 2006-1-20 09:08:00 | 显示全部楼层
发表于 2006-9-17 19:29:00 | 显示全部楼层
好呀
发表于 2006-9-18 15:24:00 | 显示全部楼层
好呀好呀!!!
发表于 2006-9-21 10:31:00 | 显示全部楼层
加载后提示字符串有缺陷!
发表于 2006-9-21 13:43:00 | 显示全部楼层
(defun c:test(/ ss nn st lay)
  (command ".undo" "be")
  (princ "请选择欲关闭图层中的对象 < 可框选 >:")
  (if (setq ss (ssget))
      (setq nn (sslength ss) st 0)
      (repeat nn
        (setq lay (cdr (assoc 8 (entget (ssname ss st)))))
        (if (or (= (strcase lay) (getvar "clayer"))(= lay (getvar "clayer")))
          (command ".layer" "off" lay "y" "")
          (command ".layer" "off" lay "")
        (setq st (1+ st))
    (princ "\n没有选中物件.")
  (command ".undo" "e")
  (prin1)
发表于 2006-9-28 12:57:00 | 显示全部楼层
好用吗?
发表于 2006-9-28 16:48:00 | 显示全部楼层
能告诉我怎么用吗
发表于 2006-9-29 08:21:00 | 显示全部楼层
楼主,什么东西都用不了呢,请解释!!!!!!!?????????
发表于 2006-11-4 21:46:00 | 显示全部楼层
楼主的LSP不完整,不过6楼的哥们儿的做的不错!
GMT+8, 2025-9-19 03:54 , Processed in 0.166325 second(s), 26 queries , Gzip On.
