;; SORRY!命令名称都一样<FOR TEST ONLY> ;; DelFile ;; BY 龙龙仔 ;; Deletes existing files ;; Arguments [Typ]: ;; Fil = FileName, "C:\\test\\Autoexec.bat" [STR] ;; Notes: ;; - Requires ScrRun.dll. ;; USAGE: (DelFile "C:\\test\\Autoexec.bat") (defun DELFILE (FIL /) (vlax-invoke (vlax-create-object "scripting.FileSystemObject") "deletefile" FIL :vlax-false ) (princ) )
;; DelFolder ;; BY 龙龙仔 ;; Deletes a directory and all of its subdirectories. ;; Arguments [Typ]: ;; Fil = FolderName, "C:\\test" [STR] ;; Notes: ;; - Requires ScrRun.dll. ;; USAGE: (DelFolder "C:\\test") (defun DELFOLDER (FIL /) (vlax-invoke (vlax-create-object "scripting.FileSystemObject") "deletefolder" FIL :vlax-false ) (princ) )
;; DelFile ;; BY 龙龙仔 ;; 能删除所有档案 ;; Deletes existing files ;; Arguments [Typ]: ;; Fil = FileName, "C:\\test\\Autoexec.bat" [STR] ;; Notes: ;; - Requires ScrRun.dll. ;; USAGE: (DelFile "C:\\test\\*.*") ;; USAGE: (DelFile "C:\\test\\Autoexec.bat") (defun DELFILE (FIL / FILSYS FILDIR SS ENT) (setq FILSYS (vlax-create-object "scripting.FileSystemObject")) (setq FILDIR (vl-filename-directory FIL)) (setq SS (vl-directory-files FILDIR (strcat (vl-filename-base FIL) (vl-filename-extension FIL)) 0 ) ) (foreach ENT SS (vlax-invoke FILSYS "deletefile" (strcat FILDIR "\\" ENT) :vlax-false ) ) (vlax-release-object FILSYS) (princ) )
;; DelFile ;; BY 龙龙仔 ;; 对属性为只读的档案不能删除 ;; Deletes existing files ;; Arguments [Typ]: ;; Fil = FileName, "C:\\test\\Autoexec.bat" [STR] ;; Notes: ;; - Requires ScrRun.dll. ;; USAGE: (DelFile "C:\\test\\*.*") ;; USAGE: (DelFile "C:\\test\\Autoexec.bat") (defun DELFILE (FIL / FILDIR SS ENT) (setq FILDIR (vl-filename-directory FIL)) (setq SS (vl-directory-files FILDIR (strcat (vl-filename-base FIL) (vl-filename-extension FIL)) 0 ) ) (foreach ENT SS (vl-file-delete (strcat FILDIR "\\" ENT)) ) (princ) )
