查看: 2836|回复: 3
局部放大
发表于 2006-1-23 15:48:00 | 显示全部楼层 |阅读模式
那位高手能把小鱼儿的局部放大完善一下.
 楼主| 发表于 2006-1-23 16:50:00 | 显示全部楼层
(vl-load-com)
;;;(alert "\\n局部放大jbfd.2004.2.18")
(defun c:jbfd (/ *error*  mSpace   cir    i     NEXT_PT
        READTYP READVAL  basept   line    text     tzz
        txtlen l2  l2end   cen    pt     text_x
        ptt l2_x  fh   fh1    ss1
        MakeUnNameBlock
  (defun *error* (msg / ent count)
    (cond
      ((or (= msg "函数被取消") (= msg "function cancelled"))
       (command "_.ERASE" ss1 "")
      ((= msg "ActiveX 服务器返回到: 未知名?: Center") ;清理输入d
       (alert (strcat "唉,我无法清理\\"d\\"??,"
        "\\n如果你知道!请通知我。"
        "\\nE_mail:cag25@sohu.com"
        "\\nQQ:297240086"
      (T
       (alert (strcat msg
        "\\n\\n对不起,有什么问题,请通知我。"
        "\\nQQ:297240086"
  (setq mSpace (vla-get-ModelSpace
   (vla-get-ActiveDocument (vlax-get-acad-object))
  (setq ss1 (ssadd))
  (defun MakeUnNameBlock (ss pt / count entlist ent blk)
    (entmake (list '(0 . "BLOCK")
     '(2 . "*U")
     '(70 . 1)
     (cons 10 pt)
    (setq count 0)
    (repeat (sslength ss)
      (setq entlist (entget (setq ent (ssname ss count))))
      (setq count (1+ count))
      (entmake entlist)
    (setq count 0)
      (entdel ent)
    (setq blk (entmake '((0 . "ENDBLK"))))
    (if T
      (entmake (list (cons 0 "INSERT")
       (cons 2 blk)
       (cons 10 pt)
  (defun Tzz (Text / textent ang sinrot cosrot t1 t2 p0 p1 p2 p3 p4)
    (setq textent (entget (vlax-vla-object->ename Text)))
    (setq p0  (cdr (assoc 10 textent))
   ang  (cdr (assoc 50 textent))
   sinrot (sin ang)
   cosrot (cos ang)
   t1  (car (textbox textent))
   t2  (cadr (textbox textent))
   p1  (list
     (+ (car p0)
        (- (* (car t1) cosrot) (* (cadr t1) sinrot))
     (+ (cadr p0)
        (+ (* (car t1) sinrot) (* (cadr t1) cosrot))
   p2  (list
     (+ (car p0)
        (- (* (car t2) cosrot) (* (cadr t1) sinrot))
     (+ (cadr p0)
        (+ (* (car t2) sinrot) (* (cadr t1) cosrot))
    (distance p1 p2)
  (setvar "cmdecho" 0)
  (initget 1)
  (setq p1 (getpoint "\\n指定放大中心点"))
  (command "circle" p1)
  (princ
    (strcat "\\n指定放大半径 <" (rtos (getvar "CIRCLERAD")) ">:")
  (command pause)
  (setq newcircle (entlast))
  (setq cir (vlax-ename->vla-object (entlast)))
  (vla-put-color cir (getvar "dimclrd"))
  (vla-update cir)
  (ssadd (entlast) ss1)
  (setq cen (vlax-safearray->list
       (vlax-variant-value (vla-get-center cir))
  (setq pt (car cen))
  (princ "\\n指定字符号放置位置 <左键或回车修改字符号>:")
  (setq i T)
  (while i
    (Setq NEXT_PT (GrRead T 4 0)
   READTYP (car NEXT_PT)
   READVAL (cadr NEXT_PT)
    (cond
      ((= READTYP 5)   ;移动
       (setq NEXT_PT (cadr NEXT_PT))
       (setq next_pt (trans next_pt 1 0))
       (setq basept (vlax-curve-getclosestpointto cir NEXT_PT))
       (if (not line)
    (if (not fh)
      (setq fh "A")
    (setq text (vla-addtext
   mspace
   fh
   (vlax-3d-point next_pt)
   (getvar "dimtxt")
    (vla-put-color text (getvar "dimclrt"))
    (vla-put-stylename text (getvar "dimtxsty"))
    (vla-update text)
    (setq line (vla-addline
   mspace
   (vlax-3d-point basept)
    (vla-put-color line (getvar "dimclrd"))
    (setq txtlen (tzz text))
    (setq l2end (list (+ (car next_pt) txtlen) (cadr next_pt) 0))
    (setq l2 (vla-addline
        mspace
        (vlax-3d-point l2end)
    (vla-put-color l2 (getvar "dimclrd"))
    (vla-put-startpoint line (vlax-3d-point basept))
    (vla-put-endpoint line (vlax-3d-point next_pt))
    (vla-update line)
    (setq ptt (car next_pt))
    (if (> ptt pt)
        (setq text_x (+ (car next_pt) (getvar "dimgap")))
        (setq l2_x (+ (car next_pt) txtlen (getvar "dimgap")))
        (setq text_x (- (car next_pt) (getvar "dimgap") txtlen))
        (setq l2_x text_x)
    (vla-put-insertionpoint
      text
      (vlax-3d-point
        (list text_x (+ (cadr next_pt) (getvar "dimgap")) 0)
    (vla-update text)
    (vla-put-startpoint l2 (vlax-3d-point next_pt))
    (setq l2end (list l2_x (cadr next_pt) 0))
    (vla-put-endpoint l2 (vlax-3d-point l2end))
    (vla-update l2)
      ((= READTYP 3)   ;左键
;;;       (MakeUnNameBlock ss1 cen)
       (setq i nil)
      ((or (= 25 readtyp) (= 13 READVAL)) ;回车或右键
       (setq fh1 fh)
       (setq fh (getstring (strcat
        "\\n?入新字符号 <"
        fh
       (if (= fh "")
  (setq fh fh1)
       (vla-put-textstring text fh)
       (vla-update text)
       (princ "\\n指定字符号放置位置 <左键或回车修改字符字>:")
  (fd)
  (bdycad)
(defun fd (/ minpt maxpt ss2)
    (vla-getboundingbox cir 'minpt 'maxpt)
    (setq minpt (vlax-safearray->list minpt)
   maxpt (vlax-safearray->list maxpt)
    (setq ss2 (ssget "C" maxpt minpt))
    (command "copy" ss2 "" cen)
    (princ "\\n指定放大图位置:")
  (command pause)
;;;    (if (not (command pause))
;;;;;;      (MakeUnNameBlock ss1 cen)
(defun bdycad()
  (defun GetPoints2004-04-22 (lst1 / pt lst1 )
  (while (setq lst1 (member (assoc 10 lst1) lst1))
    (setq pt (append pt (list (cdr (car  lst1)))))
    (setq lst1 (cdr lst1)))
  pt
(setq ssb (ssget "x" (list (cons 10(getvar "lastpoint"))  (assoc 40 (entget newcircle)))))
(command ".POLYGON" 40 (getvar "lastpoint") "c" (+(cdr (assoc 40 (entget newcircle)))0.1))
(setq polsel (entlast))
(setq trimp (GetPoints2004-04-22 (entget polsel)))
(progn ;  强行修剪
(command ".trim" ssb "" );"f" trimp)
(setq it 0)
(repeat (- (length trimp) 1)
  (setq trp1 (nth it trimp)
 trp2 (nth (1+ it) trimp))
  (command "f" trp1 trp2 "")
  (setq it (1+ it)))
(command ""))
(progn ;  强行删除
(setq it 0)
  (if (setq erase (ssget "f" (list trp1 trp2 )))
    (command ".erase" erase ""))
  (setq it (1+ it)))
  (if (=(setq scalebb (getreal "\\n输入放大的倍数<2>:"))nil)
    (setq scalebb 2))
(command ".scale" (ssget "cp" trimp)"" (getvar "lastpoint") scalebb)
发表于 2006-1-23 20:35:00 | 显示全部楼层
快过春节了, 看到什么高兴!
发表于 2022-2-27 14:23:52 | 显示全部楼层
我来顶一下
GMT+8, 2025-5-16 04:24 , Processed in 0.162301 second(s), 25 queries , Gzip On.
