[求助]:[0206]如何处理绘製及復原的一次性 请教各位高手们 小弟做了一个等分距离偏移的程序 但在执行程序时,绘製都是一段段的偏移 无法再画面内一次完成 且復原 undo 也是一段段还原 不知道该怎样处理解决此问题呢
烦请各位高手帮忙一下
谢谢~
(defun cOK ( ) (setvar "cmdecho" 0) (setq p1 (getpoint "\n 起始点:")) (setq p2 (getpoint "\n 长度点:")) (setq p3 (getpoint "\n 宽度点:")) (setq 2ar4 (getreal "\n D.等分距离.<75>:")) (if (= 2ar4 nil)(setq 2ar4 75)) (setq en3:ang (angle p1 p2)) (setq en4:ang (angle p1 p3)) (setq dd (distance p1 p2)) (setq 2ar2 (fix (/ dd 2ar4))) (setq ww (distance p1 p3)) (setq p4 (polar p1 en4:ang (/ ww 2))) (setq p5 (polar p4 en3:ang dd)) (setq oss (getvar "osmode"))(setvar "osmode" 0) (command "_.line" p1 p3 "") (setq ob1 (entlast)) (setq 2ar5 0 ) (repeat 2ar2 (setq 2ar5 (+ 2ar5 2ar4)) (command "_.offset" 2ar5 ob1 p5 "") ) (setvar "osmode" oss) (prin1))
