我希望能有个小程序,可以将修改过的“标注文字”以特殊颜色显示。见附件,图中尺寸334为修改过的“标注文字”,其余标注文字为默认值。谢谢! ------------------------------------------------------------------------------------------------------------------------------------------------------------------------ 2008-11-26 根据七楼之前的总结,最后编好的lsp如下,但最近发现不能用于CAD 2008,特来向各位再次求助。先谢谢了。 ;尺寸修改过的特殊颜色标出change text color ;一、标注文本改成"%%c<>"、"M<>x0.75"之类的,由于有<>, ; 标注会随修改自动更新,这种情况下文字颜色也保持不变。 ;二、当text override 中不含<>时实际测量长度是100, ; text override 的不是文本是100,而是40或者一个文本等,显示为紫色。 ;三、实际测量长度是100,text override 的文本也是100,显示为蓝色 (defun c:ctc () (setvar "cmdecho" 0) (command "undo" "be") (setq ss (ssget '((0 . "DIMENSION")))) (setq l (sslength ss)) (setq i 0 j 0 ) (repeat l (setq ent (ssname ss i)) (setq obj (vlax-ename->vla-object ent)) (setq txt (vla-get-TextOverride obj)) (setq mea (vla-get-Measurement obj)) (if (/= txt "") ;_标注文本为M<>x0.75、M10.0x0.75的样式 (cond ((= (substr txt 1 1) "M") (setq k 2) (if (/= (substr txt 2 1) "<") (progn (while (and (> (ascii (substr txt k 1)) 46) (< (ascii (substr txt k 1)) 57) ) (setq k (1+ k)) ) (setq txt1 (substr txt 2 (- k 2))) (if (not (equal (atof txt1) mea 0.0001)) (vla-put-TextColor obj 3) ) (setq j (1+ j)) ) ) ) ;_标注文本为%%c<>、%%C6.0 的样式 ((= (substr txt 1 1) "%") (if (not (= (substr txt 4 1) "<")) (setq j (modify-color obj txt mea 4 j)) ) ) ;_标注文本为6-%%c<>、6-%%C1.2 的样式 ((= (substr txt 2 1) "-") (if (= (substr txt 3 1) "%") (if (not (= (substr txt 6 1) "<")) (setq j (modify-color obj txt mea 6 j)) ) (if (not (= (substr txt 3 1) "<")) (setq j (modify-color obj txt mea 3 j)) ) ) ) ;_标注文本为<>、6.0的形式 (T (if (not (= (substr txt 1 1) "<")) (setq j (modify-color obj txt mea 1 j)) ) ) ) ) (setq i (1+ i)) ) (command "undo" "e") (setvar "cmdecho" 1) (if (= j 0) (princ "\n 程序执行完毕,未发现手工修改过的尺寸!") (princ (strcat "\n 共发现" (rtos j) "个尺寸被修改过")) ) (princ) ) (defun modify-color (obj0 txt0 mea0 k0 j0 / jj txt11) (setq txt11 (substr txt0 k0)) (if (equal (atof txt11) mea0 0.0001) (vla-put-TextColor obj0 5) (vla-put-TextColor obj0 6) ) (setq jj (1+ j0)) jj ) |
