查看: 1980|回复: 2
求助方法AddPolyfaceMesh得用法?
发表于 2006-2-13 22:06:00 | 显示全部楼层 |阅读模式
不明白后面点和面是怎么组合的?
发表于 2006-2-13 22:52:00 | 显示全部楼层
<RE class=Code>这是AutoCAD帮助中的例子:</PRE><RE class=Code>
  1. <PRE class=Code>Sub Example_AddPolyfaceMesh()
  2.
  3.     Dim vertexList(0 To 17) As Double
  4.     'Data
  5.     vertexList(0) = 4: vertexList(1) = 7: vertexList(2) = 0
  6.     vertexList(3) = 5: vertexList(4) = 7: vertexList(5) = 0
  7.     vertexList(6) = 6: vertexList(7) = 7: vertexList(8) = 0
  8.     vertexList(9) = 4: vertexList(10) = 6: vertexList(11) = 0
  9.     vertexList(12) = 5: vertexList(13) = 6: vertexList(14) = 0
  10.     vertexList(15) = 6: vertexList(16) = 6: vertexList(17) = 1
  11.
  12.     Dim FaceList(0 To 7) As Integer
  13.     FaceList(0) = 1
  14.     FaceList(1) = 2
  15.     FaceList(2) = 5
  16.     FaceList(3) = 4
  17.     FaceList(4) = 2
  18.     FaceList(5) = 3
  19.     FaceList(6) = 6
  20.     FaceList(7) = 5
  21.     Dim obj As AcadPolyfaceMesh
  22.     Set obj = ModelSpace.AddPolyfaceMesh(vertexList, FaceList)
  23.     obj.Update
  24.     ' Change the viewing direction of the viewport to
  25.     ' better see the polyface mesh
  26.     Dim NewDirection(0 To 2) As Double
  27.     NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
  28.     ThisDrawing.ActiveViewport.direction = NewDirection
  29.     ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
  30.     ZoomAll
  31. End Sub</PRE>
</PRE>
 楼主| 发表于 2006-2-14 08:27:00 | 显示全部楼层
谢谢帮忙,看懂了!
GMT+8, 2025-5-4 21:30 , Processed in 0.203223 second(s), 32 queries , Gzip On.
