查看: 1829|回复: 2
求助
发表于 2003-2-12 11:36:00 | 显示全部楼层 |阅读模式
我寫了如下程式,在Acad2000,2002英文版可用,為什麼在另一PC(沒有安裝VC及OBJARX)上的ACAD2002中文版不可用,arxload 沒問題,運行時出錯.提示為:
  *.arx ARX命令發生異常
  未處理的異常E06D7363(e06d7363h),地址:77E69B01H.
  ADS 請求錯誤.
程式如下請幫我看一下:
#include "StdAfx.h"
#include "StdArx.h"
// This is command 'FOXREAD'
int FOXREAD()
        resbuf *pArg =acedGetArgs () ;
        char *refname = "NetSend.mdb";
        char fullpath[100];
        if (acedFindFile(refname, fullpath) != RTNORM) return(RTNORM);
        CDaoDatabase db;
        db.Open(fullpath);
        CDaoTableDef td(&db);
        td.Open(pArg->resval.rstring);
        CDaoRecordset rs;
        rs.Open(&td,dbOpenTable,0);
        char arrstr[150][22][20];
        struct resbuf *head=0,*eb1=0,*eb2=0;
        int j=0;
        while(!rs.IsEOF())
                eb1=new resbuf;
                eb1->rbnext=NULL;
                eb1->restype = RTLB;
                if(eb2!=NULL)
                        eb2->rbnext=eb1;
                        eb2=eb1;
                for(int i=0;i<rs.GetFieldCount();i++)
                        if(head==NULL)
                                head=eb2=eb1;
                                eb2->rbnext=eb1;
                                eb2=eb1;
                        eb1=new resbuf;
                        eb1->rbnext=NULL;
                        strcpy(arrstr[j],V_BSTRT(&(rs.GetFieldValue(i))));
                        eb1->resval.rstring = arrstr[j];
                        eb1->restype = RTSTR;
                        eb2->rbnext=eb1;
                        eb2=eb1;
                eb1=new resbuf;
                eb1->restype = RTLE;
                eb1->rbnext=NULL;
                eb2->rbnext=eb1;
                eb2=eb1;
                rs.MoveNext();
                j++;
        rs.Close();
        td.Close();
        db.Close();
        eb2->rbnext=NULL;
        acedRetList(head);
        delete(eb1);
        return (RTNORM) ;
发表于 2003-2-13 17:56:00 | 显示全部楼层
Because you used : CDaoDatabase ; you must install it firstly.
you can download something from the below web to install:
http://www.microsoft.com/data/download_250rtm.htm
 楼主| 发表于 2003-2-25 18:13:00 | 显示全部楼层
我裝了MDAC2.5提示說已經安裝過了,裝MDAC2.6之後還是不能用 怎麼回事(Arx)
GMT+8, 2025-5-22 23:07 , Processed in 0.178290 second(s), 23 queries , Gzip On.
