查看: 2554|回复: 9
这是我在一本书上找到的LISP程序,可以在画矩形的同时显示出边长和面积[求助]
发表于 2003-2-12 21:01:00 | 显示全部楼层 |阅读模式
这是我在一本书上找到的LISP程序,可以在画矩形的同时显示出边长和面积,但总提示错误。哪位高手帮我调试一下,谢谢!
(defun drawbox (pt1 pt2 / pt3 pt4)
       (grdraw pt1
          (setq pt3 (list (car pt2) (cadr pt1))) -1)
       (grdraw pt1
          (setq pt4 (list (car pt1) (cadr pt2))) -1)
       (grdraw pt3 pt2 -1)
       (grdraw pt4 pt2 -1))
(defun C:ROOM (/ llp p loop urp source pt lrp ulp)
       (initget 1)
       (setp llp (getpoint "\nFirst point :") urp llp loop t)
       (drawbox llp urp)
       (prompt "\nScond point :")
       (while loop
              (setq urp1 (grread t))
              (setq source (car urp1) pt (cadr urp1))
              (cond
                ((and (= source 5)
                 (or (/= (car urp) (car pt))
                     (/= (cadr urp) (cadr pt))
              (drawbox llp utp)
              (setq w (- (car urp) (car llp)))
              (setq l (- (cadr urp) (cadr llp)))
              (setq sm (* (/ w 1000.0) (/ l 1000.0)))
              (setq x (strcat (rtos w 2 0) "x"
                              (rtos l 2 0) "A=" (rtos (ads sm) 2 2)))
              (grtext -2 x)
         (drawbox llp pt)
         (setp urp pt)
       ((or (= source 3)
        (and (= source 2) (or (= pt 13) (= pt 32))))
        (drawbox llp urp)
        (setq loop nil))))
        (setq lrp (list (car urp) (cadr llp)))
        (setq ulp (list (car llp) (cadr uru)))
       (command "pline" llp "w" 240 240 lrp urp ulp "c")
发表于 2003-2-13 17:09:00 | 显示全部楼层
有些字母没拼对:setp->setq, ads->abs, utp->urp
发表于 2003-2-13 17:10:00 | 显示全部楼层
还有,程序好象没有显示面积及财长的句子
发表于 2003-2-14 08:20:00 | 显示全部楼层
修改..OK.可以在画矩形的同时显示出边长和面积
(defun DRAWBOX (PT1 PT2 / PT3 PT4)
  (grdraw PT1
          (setq PT3 (list (car PT2) (cadr PT1)))
          -1
  (grdraw PT1
          (setq PT4 (list (car PT1) (cadr PT2)))
          -1
  (grdraw PT3 PT2 -1)
  (grdraw PT4 PT2 -1)
(defun C:ROOM (/ LLP P LOOP URP SOURCE PT LRP ULP)
  (initget 1)
  (setq        LLP  (getpoint "\nFirst point :")
        URP  LLP
        LOOP t
  (DRAWBOX LLP URP)
  (while LOOP
    (setq URP1 (grread t 1 0))
    (setq SOURCE (car URP1)
          PT         (cadr URP1)
    (cond
      ((and (= SOURCE 5)
            (or        (/= (car URP) (car PT))
                (/= (cadr URP) (cadr PT))
         (DRAWBOX LLP URP)
         (setq W (- (car URP) (car LLP)))
         (setq L (- (cadr URP) (cadr LLP)))
         (setq SM (* (/ W 10.0) (/ L 10.0)))
         (setq X (strcat (rtos (abs (/ W 10)) 2 1)
                         "cm*"
                         (rtos (abs (/ L 10)) 2 1)
                         "cm 面积= "
                         (rtos (abs SM) 2 2)
                         "cm^2"
                    ;;(grtext 1 X)
         (setvar "MODEMACRO" X)
       (DRAWBOX LLP PT)
       (setq URP PT)
      ((or (= SOURCE 3)
           (and (= SOURCE 2) (or (= PT 13) (= PT 32)))
       (DRAWBOX LLP URP)
       (setq LOOP NIL)
  (setq LRP (list (car URP) (cadr LLP)))
  (setq ULP (list (car LLP) (cadr URP)))
  (command "pline" LLP LRP URP ULP "c")
 楼主| 发表于 2003-2-15 22:26:00 | 显示全部楼层
谢谢!谢谢高手!不过......
谢谢!谢谢高手!不过这个程序和我预想的有一些差别,我想边长的单位应是毫米,面积的单位应是平方米。这样符合建筑绘图习惯,另外如果能同时绘出墙厚,显示出轴线面积和使用面积,就是一个非常好的草图绘制工具了!
发表于 2003-2-16 14:38:00 | 显示全部楼层
Drawbox中的grdraw还可以用Grvecs的,配合Matrix比Grdraw更强大。
找Grread应用的例子很久了,谢谢。
发表于 2003-2-17 12:25:00 | 显示全部楼层
配合Matrix比Grdraw(有例子嗎?)
发表于 2003-2-20 18:51:00 | 显示全部楼层
没有,不过找到个用VLSP实现动态移动旋转缩放的方法。
尝试着写了,发现个问题鼠标移动后没法消除前面画的就放弃了。
不过找到了一个VLISP实现动态缩放、移动、旋转的方法,用Grread跟踪点,然后构造跟踪点相对基点的矩阵(平移、旋转或缩放),然后用Transformby作用实体。
发表于 2012-3-10 22:55:58 | 显示全部楼层
路过,学习了。这个帖子还得到明总的指点,高兴啊
发表于 2012-3-10 23:15:05 | 显示全部楼层
几世纪的东西都能翻出来,拜服。
GMT+8, 2025-9-25 02:48 , Processed in 0.199343 second(s), 27 queries , Gzip On.
