各位大侠,我用vb在cad中填充自已的图案时,最后求值出错,但如果是cad本身自带的图库则不出错,不知为什么,求各位大侠帮帮我呀!!
Dim hatchObj As AcadHatch '定义填充对象变量 Dim patternName As String '定义图案填充名称 Dim PatternType As Long '定义图案填充类型 Dim bAssociativity As Boolean '定义图案填充与边界是否关联的布尔变量 PatternType = acHatchPatternTypeCustomDefined '使填充类型为自定义的图案填充,在此如果换成acHatchPatternTypepredefined,把下面的b056换成ANSI31,程序则不出错 patternName = "b056" '填充文件名为b056.pat的自定义图案填充文件 bAssociativity = true '关联边界 Set hatchObj = acadapp.ActiveDocument.ModelSpace.AddHatch(PatternType, patternName, bAssociativity)
'创建填充对象 Dim outerLoop(0 To 3) As AcadEntity Dim innerloop(0 To 3) As AcadEntity Dim startpoint1(0 To 2) As Double Dim endpoint1(0 To 2) As Double Dim startpoint2(0 To 2) As Double Dim endpoint2(0 To 2) As Double Dim startpoint3(0 To 2) As Double Dim endpoint3(0 To 2) As Double Dim startpoint4(0 To 2) As Double Dim endpoint4(0 To 2) As Double Dim pa As Double startpoint1(0) = -50#: startpoint1(1) = -50#: startpoint1(2) = 0# endpoint1(0) = 50#: endpoint1(1) = -50#: endpoint1(2) = 0# startpoint2(0) = 50#: startpoint2(1) = -50#: startpoint2(2) = 0# endpoint2(0) = 50#: endpoint2(1) = 50#: endpoint2(2) = 0# startpoint3(0) = 50#: startpoint3(1) = 50#: startpoint3(2) = 0# endpoint3(0) = -50#: endpoint3(1) = 50#: endpoint3(2) = 0# startpoint4(0) = -50#: startpoint4(1) = 50#: startpoint4(2) = 0# endpoint4(0) = -50#: endpoint4(1) = -50#: endpoint4(2) = 0#
'为填充边界四边形定义数组及为其赋值 Set outerLoop(0) = acadapp.ActiveDocument.ModelSpace.AddLine(startpoint1, endpoint1) Set outerLoop(1) = acadapp.ActiveDocument.ModelSpace.AddLine(startpoint2, endpoint2) Set outerLoop(2) = acadapp.ActiveDocument.ModelSpace.AddLine(startpoint3, endpoint3) Set outerLoop(3) = acadapp.ActiveDocument.ModelSpace.AddLine(startpoint4, endpoint4)
'创建填充边界四边形 hatchObj.AppendOuterLoop (outerLoop)
'用自定义库为四边形填充 hatchObj.Evaluate
'用Evaluate方法进行求值,程序在此出错 acadapp.ActiveDocument.Regen acActiveViewport acadapp.ActiveDocument.SaveAs "c:\wxy.dwg" acadapp.Application.Visible = True ZoomExtents '显示图形
