查看: 3134|回复: 4
在VBA中引用EXCEL 对象后如何弹出EXCEL保存对话框?
发表于 2006-3-9 16:04:00 | 显示全部楼层 |阅读模式
我是一个VBA入门者,请问在VBA中引用EXCEL 对象后如何弹出EXCEL保存对话框?
Sub PgDxx()
 Dim Excel As Excel.Application
 Dim ExcelSheet As Object
 Dim ExcelWorkbook As Object
 Dim RowNum As Integer
 Dim HeadTF As Boolean
 Dim Elem As AcadEntity
 Dim Array1 As Variant
 Dim Count As Integer
 Set Excel = New Excel.Application
 Set ExcelWorkbook = Excel.Workbooks.Add
 Set ExcelSheet = Excel.ActiveSheet
 ExcelWorkbook.SaveAs "d:\dwgdata.xls"
 ExcelSheet.Cells(1, 1).Value = "点号"
 ExcelSheet.Cells(1, 2).Value = "方位"
 ExcelSheet.Cells(1, 3).Value = "平距"
 ExcelSheet.Cells(1, 4).Value = "高程"
 DIS = 0
 For i = 1 To 200
   ExcelSheet.Cells(i + 1, 1).Value = i
   pt(i) = vbCrLf & "捕捉剖面图切点:"
   hint(i) = ThisDrawing.Utility.GetPoint(, pt(i))
   H(i) = vbCrLf & "输入该点高程(结束请输入“0”):"
    On Error Resume Next
   Hi(i) = ThisDrawing.Utility.GetReal(H(i))
    If Hi(i) = 0 Then Exit For
   ExcelSheet.Cells(i + 1, 4).Value = Hi(i)
   If i > 1 Then
     DIS = GetDIS(hint(i), hint(i - 1)) + DIS
     angle = GetAngle(hint(i - 1), hint(i))
   End If
 If i > 1 Then ExcelSheet.Cells(i, 2).Value = Format(angle, "###")
  ExcelSheet.Cells(i + 1, 3).Value = Format(DIS, "####.00")
   Next i
    ' Close the recordset and the database connection
    ExcelWorkbook.Close
    Excel.Application.Quit
End Sub
我希望在红字处弹出EXCEL保存对话框,哪位大哥能告诉我。小弟在此谢过了。!!!
发表于 2006-3-9 18:15:00 | 显示全部楼层
你可以调用VB中的保存对话框呀
 楼主| 发表于 2006-3-9 22:02:00 | 显示全部楼层
实在是不好意思,zhul,我也不知道如何调用VB中的保存对话框,望指点,多谢多谢
 楼主| 发表于 2006-3-10 10:52:00 | 显示全部楼层
多谢,我经过一宿的研究终于搞定。多谢了,zhul
发表于 2006-3-11 10:53:00 | 显示全部楼层
要是不会调用保存对话框就自己做一个Form,也是个变通的方法,速度也不会慢到哪去......
GMT+8, 2025-5-4 16:17 , Processed in 0.160224 second(s), 23 queries , Gzip On.
