试试这个
;;;图元合并 (defun c:tyhb (/ ARC_LIST ENT I LINE_LIST SS) (while (and (setq ss (ssget (list (cons -4 "<or") (cons 0 "arc") (cons 0 "CIRCLE") (cons 0 "line") (cons -4 "or>") ) ) ) (> (sslength ss) 0) ) (hbzhx ss) ) (princ) ) (defun cs_pross (to i / CS_TEXT MYI) (setq cs_text ">>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>") (setq myi (fix (/ (* (strlen cs_text) i) to)) cs_text (substr cs_text 1 myi) ) (grtext -2 cs_text) )
(defun hbzhx ( ss / ARC_LIST ENT I LINE_LIST SS jd) ;;; 转为数据表 (grtext -2 "正在整理数据") (setq i 0 jd 1e-5 line_list ' () arc_list '() ) (repeat (sslength ss) (setq ent (ssname ss i) i (1+ i) ) (if (= "LINE" (cdr (assoc 0 (entget ent)))) (setq line_list (cons (line_data ent) line_list)) (setq arc_list (cons (arc_data ent) arc_list)) ) ) (setq line_list (vl-sort line_list '(lambda (e1 e2) (if (equal (car e1) (car e2) jd) (if (equal (cadr e1) (cadr e2) jd) (if (equal (car (caddr e1)) (car (caddr e2)) jd) (< (cadr (caddr e1)) (cadr (caddr e2))) (< (car (caddr e1)) (car (caddr e2))) ) (< (cadr e1) (cadr e2)) ) (< (car e1) (car e2)) ) ) ) ) (setq arc_list (vl-sort arc_list '(lambda (e1 e2) (if (equal (car e1) (car e2) jd) (if (equal (cadr e1) (cadr e2) jd) (if (equal (caddr e1) (caddr e2) jd) (< (cadddr e1) (cadddr e2)) (< (caddr e1) (caddr e2)) ) (< (cadr e1) (cadr e2)) ) (< (car e1) (car e2)) ) ) ) ) (if line_list (hb_line line_list jd)) (if arc_list (hb_arc arc_list jd)) (grtext) (princ) ) (defun hb_line (line_list jd / B BIAOJI DATA ENT K LINE_A LINE_B P1 P2 P3 P4 P5 JD XUHAO ZONGSHU i lay) (setq zongshu (length line_list) i 0 xuhao 0) (princ (strcat "\n共处理" (rtos zongshu) "个实体")) (grtext -1 "合并直线") (while (> (length line_list) 0) (setq xuhao (1+ xuhao)) (cs_pross zongshu xuhao) (setq line_a (car line_list) line_list (cdr line_list) biaoji t k (car line_a) b (cadr line_a) p1 (caddr line_a) p2 (cadddr line_a) ent (last line_a) lay (cdr (assoc 8 (entget ent))) ) (while (and biaoji (> (length line_list) 0) ) (setq line_b (car line_list) ) (cond ((and (equal k (car line_b) jd) (equal b (cadr line_b) jd) (= lay (cdr (assoc 8 (entget (last line_b))))) ) (setq p3 (caddr line_b) p4 (cadddr line_b) p5 (vl-sort (list p1 p2 p3 p4) '(lambda (e1 e2) (if (equal (car e1) (car e2) jd) (< (cadr e1) (cadr e2)) (< (car e1) (car e2)) ) ) ) p4 (cadr p5) ) (if (or (equal p1 p4 jd) (equal p3 p4 jd) ) (progn (setq p1 (car p5) p2 (last p5) line_list (cdr line_list) ) (entdel (last line_b)) (setq xuhao (1+ xuhao)) (cs_pross zongshu xuhao) (setq i (1+ i)) ) (setq biaoji nil) ) ) (t (setq biaoji nil)) ) ) (setq data (entget ent) data (subst (cons 10 p1) (assoc 10 data) data) data (subst (cons 11 p2) (assoc 11 data) data) ) (entmod data) ) (princ (strcat ",删除了" (rtos i) "个实体")) (princ) ) (defun hb_arc (arc_list jd / i ARC_A ARC_B BIAOJI BJ DATA EANGL EANGL1 ENT JD LINE_LIST P5 PC SANGL SANGL1 XUHAO ZONGSHU lay) (setq zongshu (length arc_list) xuhao 0 i 0) (princ (strcat "\n共处理" (rtos zongshu) "个实体")) (grtext -1 "合并圆弧") (while (> (length arc_list) 0) (setq xuhao (1+ xuhao)) (cs_pross zongshu xuhao) (setq arc_a (car arc_list) arc_list (cdr arc_list) biaoji t bj (car arc_a) pc (list (cadr arc_a) (caddr arc_a)) sangl (cadddr arc_a) eangl (nth 4 arc_a) ent (last arc_a) lay (cdr (assoc 8 (entget ent))) ) (while (and biaoji (> (length arc_list) 0) ) (setq arc_b (car arc_list) ) (cond ((and (equal bj (car arc_b) jd) (equal pc (list (cadr arc_b) (caddr arc_b)) jd) (= lay (cdr (assoc 8 (entget (last arc_b))))) ) (setq sangl1 (cadddr arc_b) eangl1 (nth 4 arc_b) p5 (vl-sort (list sangl eangl sangl1 eangl1) '(lambda (e1 e2) (< e1 e2) ) ) sangl1 (nth (- (length p5) 2) p5) ) (if (or (equal eangl sangl1 jd) (equal eangl1 sangl1 jd) ) (progn (setq sangl (car p5) eangl (last p5) arc_list (cdr arc_list) ) (entdel (last arc_b)) (setq xuhao (1+ xuhao)) (cs_pross zongshu xuhao) (setq i (1+ i)) ) (setq biaoji nil) ) ) (t (setq biaoji nil)) ) ) (setq data (entget ent) data (subst (cons 50 sangl) (assoc 50 data) data) data (subst (cons 51 eangl) (assoc 51 data) data) ) (entmod data) ) (princ (strcat ",删除了" (rtos i) "个实体")) (princ) ) (defun arc_data (ent / BJ DATA EANGL PC SANGL) (setq data (entget ent)) (setq bj (cdr (assoc 40 data))) (setq pc (cdr (assoc 10 data))) (setq sangl (cdr (assoc 50 data))) (setq eangl (cdr (assoc 51 data))) (if (not sangl) (setq sangl 0.0 eangl (+ pi pi) ) ) (if (< eangl sangl) (setq eangl (+ eangl (+ pi pi))) ) (list bj (car pc) (cadr pc) sangl eangl ent) )
(defun line_data (ent / B K P1 P2 jd) (setq p1 (vlax-curve-getstartpoint ent) p2 (vlax-curve-getendpoint ent) jd 1e-5 ) (if (equal (car p1) (car p2) jd) (setq k nil b (car p1) ) (setq k (/ (- (cadr p2) (cadr p1)) (- (car p2) (car p1)) ) b (- (cadr p1) (* (car p1) k)) ) ) (setq p2 (vl-sort (list p1 p2) '(lambda (e1 e2) (if (equal (car e1) (car e2) jd) (< (cadr e1) (cadr e2)) (< (car e1) (car e2)) ) ) ) p1 (car p2) p2 (cadr p2) ) (list k b (list (car p1) (cadr p1)) (list (car p2) (cadr p2)) ent ) ) |
