查看: 1512|回复: 2
(求助)请帮我看一下这段代码为什么不行?
发表于 2006-3-20 13:14:00 | 显示全部楼层 |阅读模式
本人初学VBA,请各位多多指教,这段代码为什么不行
找到实体层中各直线的交点,并把它们打印出来.
 Sub findpoint()
Dim newlayer As AcadLayer
Dim intpoints As Variant
Set newlayer = ThisDrawing.Layers("实体层")
ThisDrawing.ActiveLayer = newlayer
For Each lineobj1 In ThisDrawing.ModelSpace
  For Each lineobj2 In ThisDrawing.ModelSpace
    If lineobj1.ObjectID <> lineobj2.ObjectID Then
      intpoints = lineobj1.IntersectWith(lineobj2.acExtendNone)
    End If
  Next
Next
Dim i As Integer, j As Integer, k As Integer
Dim str As String
If VarType(intpoints) <> vbEmpty Then
        For i = LBound(intpoints) To UBound(intpoints)
            str = "Intersection Point[" & k & "] is: " & intpoints(j) & "," & intpoints(j + 1) & "," & intpoints(j + 2)
            MsgBox str, , "IntersectWith Example"
            str = ""
            i = i + 2
            j = j + 3
            k = k + 1
        Next
    End If
End Sub
      谢谢大家了
发表于 2006-3-20 14:21:00 | 显示全部楼层
问题出在这里:
    End If
lineobj2.acExtendNone,该是“lineobj2,acExtendNone”而不是一个“.”
 楼主| 发表于 2006-3-20 14:36:00 | 显示全部楼层
太感谢你了,都是我马虎造成的,给大家添麻烦了
GMT+8, 2025-5-4 16:29 , Processed in 0.159576 second(s), 23 queries , Gzip On.
