查看: 2531|回复: 5
[求助]我在cad用的画图命令,已经用过了zoomall,和Update.怎么在画图区没有显示出图
发表于 2003-2-19 11:17:00 | 显示全部楼层 |阅读模式
[求助]我在cad用的画图命令,已经用过了zoomall,和Update.怎么在画图区没有显示出图形。[br]
发表于 2003-2-19 13:11:00 | 显示全部楼层
说得不够清楚,如果是程序的话最好能贴出来
 楼主| 发表于 2003-2-19 14:44:00 | 显示全部楼层
大至就是类似下面这段程序,只要这里能画图的话,其它应该都是这种情况了。拜托了!
大至就是类似下面这段程序,只要这里能画图的话,其它应该都是这种情况了。拜托了!!![br]Public acadobj As Object         'ThisDrawing
        Public acaddoc As AcadDocument
        Public mospace As AcadModelSpace
        Public mypaperspace As AcadPaperSpace
        Public myucs As AcadUCS
        Public utilObj As AcadUtility
        Public layerObj As AcadLayer
Private Sub Command1_Click()
        Dim textacad As AcadText
        Dim fileName As String
        On Error Resume Next
        Set acadobj = GetObject(, "AutoCAD.Application")
        If Err Then
                Err.Clear
            Set acadobj = CreateObject("AutoCAD.Application")
            If Err Then
                MsgBox Err.Description
                Exit Sub
            End If
        End If
               acadobj.Visible = True
            fileName = "C:\×÷ÒµCHEN\GBS-H2-10-05X42±¸·Ý.dwg"
        If Dir(fileName) <> "" Then
              Set acaddoc = acadobj.ActivDocument.Open(fileName)
        Else
              MsgBox "File " & fileName & " does not exist."
        End If
        Set mypaperspace = acaddoc.PaperSpace
        Set mospace = acaddoc.ModelSpace
        Set myucs = acaddoc.ActiveUCS
        Set utilObj = acaddoc.Utility
        Set layerObj = acaddoc.Layers.Add("LAYER1")
                layerObj.Color = acMagenta
End Sub
Private Sub Command2_Click()
        Dim lineObj As AcadLine
        Dim startPoint(0 To 2) As Double
        Dim EndPoint(0 To 2) As Double
        Dim i As Integer
            startPoint(0) = 10#
            startPoint(1) = 10#
            startPoint(2) = 0#
            EndPoint(0) = 100#
            EndPoint(1) = 100#
            EndPoint(2) = 0#
        For i = 0 To 2
            Debug.Print startPoint(i) & "***" & EndPoint(i)
        Next i
         Set lineObj = acaddoc.ModelSpace.AddLine(startPoint, EndPoint)
                With lineObj
                     .Color = acRed
                     .Visible = True
                     .Update
                End With
                acaddoc.ActivePViewport.ZoomAll
                acadobj.ZoomAll
                acaddoc.Save
End Sub
Private Sub Command5_Click()
            Set acaddoc = Nothing
              acadobj.Quit
            Set acadobj = Nothing
            End
End Sub
 楼主| 发表于 2003-2-19 14:47:00 | 显示全部楼层
Private Sub Command2_Click()中有没有在画图空间中显示出来。
发表于 2003-2-19 16:00:00 | 显示全部楼层
用acaddoc.Regen (acActiveViewport)可以显示出来
发表于 2003-3-26 18:28:00 | 显示全部楼层
由于你是用VB或者其他的执行程序,虽然在AUTOCAD中画图后,但焦点没有转移
AppActivate AcadApp.Caption
GMT+8, 2025-5-23 10:17 , Processed in 0.163715 second(s), 24 queries , Gzip On.
