我要填写零件表,程序运行不了,我试了试两个子程序没有问题,可能是主程序的问题,请看一下:
;---读数据写明细表---; (defun c:dataw() (setq data_list '()) (setq f (open "f:/lisp/pinfro.txt" "r")) (setq data (read(read-line f))) (while data (setq data_list (cons data data_list)) (setq data (read(read-line f)))) (close f) (setq pt1 (getpoint "\n左上角:")) (listh) (setq i 1) (setq n(length data_list)) (repeat n (setq datad (assoc i data_list)) (setq datad(nth 0 (cdr datad))) (setq xh(nth 0 datad)) (setq mc(nth 1 datad)) (setq sl(nth 2 datad)) (setq clbz(nth 3 datad)) (drlist) (setq pt1 (polar pt1 (* pi 1.5) hh)) (setq i (1+ i)) ) )
;---画明细表---; (defun drlist() (setvar "cmdecho" 0) (setq pt1x (car pt1) pt1y (cadr pt1)) (setq ww 90) (setq hh 8) (setq pt2(polar pt1 0 ww)) (setq pt3 (list(+ pt1x ww)(- pt1y hh) 0.0)) (setq pt4(polar pt1 (* pi 1.5) hh)) (command "pline" pt1 pt2 pt3 pt4 "c") (setq pt5(polar pt1 0 15)) (setq pt6(list(+ pt1x 15)(- pt1y hh)0.0)) (command "line" pt5 pt6 "") (setq pt7(polar pt1 0 45)) (setq pt8(list(+ pt1x 45)(- pt1y hh)0.0)) (command "line" pt7 pt8 "") (setq pt9(polar pt1 0 60)) (setq pt10(list(+ pt1x 60)(- pt1y hh)0.0)) (command "line" pt9 pt10 "") (command "text" "m" (inters pt1 pt6 pt4 pt5)(/ hh 2)0 (itoa xh)) (command "text" "m" (inters pt5 pt8 pt6 pt7)(/ hh 2)0 (vl-symbol-name mc)) (command "text" "m" (inters pt7 pt10 pt8 pt9)(/ hh 2)0 (itoa sl)) (command "text" "m" (inters pt9 pt3 pt10 pt2)(/ hh 2)0 (vl-symbol-name clbz)))
;---画明细表头---; (defun listh() (setvar "cmdecho" 0) (setq pt1x (car pt1) pt1y (cadr pt1)) (setq ww 90) (setq hh 8) (setq pt2(polar pt1 0 ww)) (setq pt3 (list(+ pt1x ww)(+ pt1y hh) 0.0)) (setq pt4(polar pt1 (* pi 0.5) hh)) (command "pline" pt1 pt2 pt3 pt4 "c") (setq pt5(polar pt1 0 15)) (setq pt6(list(+ pt1x 15)(+ pt1y hh)0.0)) (command "line" pt5 pt6 "") (setq pt7(polar pt1 0 45)) (setq pt8(list(+ pt1x 45)(+ pt1y hh)0.0)) (command "line" pt7 pt8 "") (setq pt9(polar pt1 0 60)) (setq pt10(list(+ pt1x 60)(+ pt1y hh)0.0)) (command "line" pt9 pt10 "") (command "text" "m" (inters pt1 pt6 pt4 pt5)(/ hh 2)0 "序号") (command "text" "m" (inters pt5 pt8 pt6 pt7)(/ hh 2)0 "零件名称") (command "text" "m" (inters pt7 pt10 pt8 pt9)(/ hh 2)0 "数量") (command "text" "m" (inters pt9 pt3 pt10 pt2)(/ hh 2)0 "材料/标准") ) |
