请教一个编程的问题
我的lisp和DCL程序如下:
(defun c:zlj() (setvar "cmdecho" 0) (setq dd 99) (setq pt '(0 0 0)) (setq kp_x 0) (setq kp_y 0) (setq kp_z 0) (while (>= dd 1) (dcl_dia13) (datanz) (def_dia13) (prin1)))
(defun dcl_dia13() (setq dcl_id (load_dialog "f:/lisp/w.dcl")) (new_dialog "dia3" dcl_id) (dispos) (mapcar 'set_tile tkey_list data_list) (set_tile "kax" "0") (set_tile "kay" "0") (set_tile "kaz" "0") (action_tile "m1" "(sub_m1)") (action_tile "m2" "(sub_m2)") (action_tile "m3" "(sub_m3)") (action_tile "m4" "(sub_m4)") ………… (action_tile "pnt" "(done_dialog 2)") (action_tile "accept" "(ok_dia13)(done_dialog 3)") (setq dd(start_dialog)) (cond ((= dd 2)(getp)(dcl_dia13)) ((= dd 3)(inst_dia13))) (unload_dialog dcl_id))
(defun sub_m1() (setq ddtype 1) (show_sld "kimage" "f:/slides/1")) (defun sub_m2() (setq ddtype 2) (show_sld "kimage" "f:/slides/2")) (defun sub_m3() (setq ddtype 3) (show_sld "kimage" "f:/slides/3")) (defun sub_m4() (setq ddtype 4) (show_sld "kimage" "f:/slides/4")) ………… (defun show_sld(key sld) (setq x (dimx_tile key)) (setq y (dimy_tile key)) (start_image key) (fill_image 0 0 x y -2) (slide_image 0 -10 x (+ y -10) sld) (end_image))
(defun ok_dia13() (setq agx (angtof(get_tile "kax"))) (setq agx (* (/ agx pi) 180)))
(defun getp() (setq pt (getpoint "\n指定插入点")))
(defun dispos() (setq kp_x(car pt)) (setq kp_y(cadr pt)) (setq kp_z(caddr pt)) (set_tile "key_x"(rtos kp_x 2 2)) (set_tile "key_y"(rtos kp_y 2 2)) (set_tile "key_z"(rtos kp_z 2 2)))
(defun inst_dia13() (cond ((= ddtype 1)(command "insert" "f:/parts/1" pt "" "" "" ) (command "rotate" (entlast) "" pt agx )(command "zoom" "a" "")) ((= ddtype 2)(command "insert" "f:/parts/2" pt "" "" "" ) (command "rotate" (entlast) "" pt agx)(command "zoom" "a" "")) ((= ddtype 3)(command "insert" "f:/parts/3" pt "" "" "" ) (command "rotate" (entlast) "" pt agx )(command "zoom" "a" "")) ((= ddtype 4)(command "insert" "f:/parts/4" pt "" "" "" ) (command "rotate" (entlast) "" pt agx )(command "zoom" "a" "")) ………… (defun datanz() (setq data_list '() data nil) (setq f (open "f:/lisp/partslist.txt" "r")) (setq data (read-line f)) (setq data (read data)) (while data (setq data_list (cons data data_list)) (setq data (read-line f)) (setq data (read data))) (close f) (setq i 1) (setq mclist '()) (setq n(length data_list)) (repeat n (setq datad (assoc i data_list)) (setq datad(nth 0 (cdr datad))) (setq mc(nth 1 datad)) (setq mclist (cons mc mclist)) (setq i (1+ i))) (setq mclist(reverse mclist)) (setq data_list(mapcar 'vl-symbol-name mclist)))
(defun def_dia13() (setq tkey_list '("mc1" "mc2" "mc3" "mc4" ……)))
现在有这样一个问题:我拾取点后希望返回的对话框的图象上有单选按纽选上的图,不希望它什么都没有,怎么处理呀? |
