查看: 2333|回复: 2
求助:如何利用vba实现将当前图形输出为.sat 的格式的文件
发表于 2003-2-20 22:34:00 | 显示全部楼层 |阅读模式
请教各位,如何利用vba实现将当前图形输出为.sat 的格式的文件
[此贴子已经被作者于2003-2-20 22:29:16编辑过]
[此贴子已经被作者于2003-2-20 22:30:11编辑过]
发表于 2003-2-21 09:31:00 | 显示全部楼层
这样
Sub main()
Dim acadapp As AcadApplication
Dim thisdrawing As AcadDocument
Set acadapp = GetObject(, "autocad.application.15")
Set thisdrawing = acadapp.ActiveDocument
Dim sel As AcadSelectionSet
Set sel = thisdrawing.ActiveSelectionSet
sel.Select acSelectionSetAll
thisdrawing.Export "c:\xx.sat", "sat", sel
End Sub
(defun c:main (/ activeselectionset thisdrawing)
  (vl-load-com)
  (setq thisdrawing (vla-get-activedocument (vlax-get-acad-object)))
  (setq activeselectionset (vla-get-activeselectionset thisdrawing))
  (vlax-invoke-method
    activeselectionset
    "select"
    acSelectionSetAll
  (vlax-invoke-method
    thisdrawing        "Export" "c:\\xxx.sat" "sat" activeselectionset)
  (vlax-release-object activeselectionset)
  (vlax-release-object thisdrawing)
 楼主| 发表于 2003-2-21 16:43:00 | 显示全部楼层
谢谢
多谢赐教
GMT+8, 2025-5-13 22:54 , Processed in 0.642788 second(s), 23 queries , Gzip On.
