查看: 2887|回复: 1
急盼高手解答
发表于 2002-4-27 10:50:00 | 显示全部楼层 |阅读模式
把一个数赋给参数x后,如何划一条以(0,0)为起点,x为长度的直线?
另外,如何使程序自动获取这条直线的两个端点?
谢谢!!!
发表于 2002-4-27 11:07:00 | 显示全部楼层
参考这个
;;;以前的回答(参考这个,希望对你有用)
;;;向高手求教:有一任意线段,如何选取一个端点后,按指定长度自动截取或延伸该线段,要求用lisp
(defun C:TEST (/ A A1 A2 A10 A11 EE DIST ANG)
  (while (= A NIL)
    (prompt "\n请选线段: ")
    (setq A (entsel))
    (setq A1 (entget (car A)))
    (if        (/= "LINE" (cdr (assoc 0 A1)))
      (setq A NIL)
  (setq A2 (osnap (cadr A) "END"))
  (setq DIST (getdist A2 "\n指定长度: "))
  (setq A10 (cdr (assoc 10 A1)));;;端点1
  (setq A11 (cdr (assoc 11 A1)));;;端点2
  (if (not (equal A2 A10))
    (setq A2  A11
          EE  10
          ANG (angle A2 A10)
    (setq EE  11
          ANG (angle A2 A11)
  (setq A1 (subst (cons EE (polar A2 ANG DIST)) (assoc EE A1) A1))
  (entmod A1)
GMT+8, 2025-6-2 06:12 , Processed in 0.183433 second(s), 25 queries , Gzip On.
