查看: 1624|回复: 4
变为当前层失败,有没有方法
发表于 2006-4-8 10:09:00 | 显示全部楼层 |阅读模式
请教大师:
本人编了一个将所选层变为当前层的Vba程式,
可是失败,请了解的朋友指点
Public Sub dq()
Dim ssetobj1 As AcadSelectionSet
Dim icount1 As Integer
icount1 = ThisDrawing.SelectionSets.Count
While (icount1 > 0)
    If ThisDrawing.SelectionSets.Item(icount1 - 1).Name = "yuan" Then
    ThisDrawing.SelectionSets.Item(icount1 - 1).Delete
    End If
    icount1 = icount1 - 1
    Wend
    Set ssetobj1 = ThisDrawing.SelectionSets.Add("yuan")
    ThisDrawing.Utility.Prompt "please select object"
    ssetobj1.SelectOnScreen
  Dim i1 As Integer
  Dim selobj1 As AcadEntity
  On Error Resume Next
      Set selobj1 = ssetobj1.Item(i1)
  Dim str As String
  str = selobj1.Layer
  ThisDrawing.ActiveLayer = str
发表于 2006-4-8 10:51:00 | 显示全部楼层
大哥,ThisDrawing.ActiveLayer是个对象,str是个字符串,看你最后的三行,应该改为:
 Dim str As String
 str = selobj1.layer
 Dim layer As AcadLayer
 For Each layer In ThisDrawing.Layers
    If layer.Name = str Then ThisDrawing.ActiveLayer = layer
 Next
发表于 2006-4-8 15:41:00 | 显示全部楼层
ThisDrawing.ActiveLayer =ThisDrawing.Layers( str )
发表于 2006-4-8 16:08:00 | 显示全部楼层
lzh741206斑竹,你的经验很丰富啊,我总是想不起来用简单的方法。。。谢啦!以后改进!
 楼主| 发表于 2006-4-8 17:28:00 | 显示全部楼层
谢谢各位大师,你们太利害了
GMT+8, 2025-10-13 04:17 , Processed in 0.148473 second(s), 23 queries , Gzip On.
