查看: 1520|回复: 1
大师们请看看
发表于 2006-4-8 17:35:00 | 显示全部楼层 |阅读模式
本人编了下面一个程式,就是选择很多物体一起偏移并删除以前的东西,但是会出现有些是内偏,而有些外偏,而如果是一个一个选,则都会外偏,请大师们过目并指教
Public Sub ttu()
Dim ssetobj1 As AcadSelectionSet
Dim icount1 As Integer
icount1 = ThisDrawing.SelectionSets.Count
While (icount1 > 0)
    If ThisDrawing.SelectionSets.Item(icount1 - 1).Name = "yuan" Then
    ThisDrawing.SelectionSets.Item(icount1 - 1).Delete
    End If
    icount1 = icount1 - 1
    Wend
    Set ssetobj1 = ThisDrawing.SelectionSets.Add("yuan")
    ThisDrawing.Utility.Prompt "please select object"
    ssetobj1.SelectOnScreen
   Dim i1 As Integer
   Dim selobj1 As Variant
   Dim shuz As Double
   shuz = ThisDrawing.Utility.GetReal("请输入偏移量 :")
  For i1 = 0 To ssetobj1.Count - 1
      Set selobj1 = ssetobj1.Item(i1)
      Dim ofselobj1 As Variant
     selobj1.Offset (shuz)
      selobj1.Delete
      Next
End Sub
发表于 2006-4-10 11:18:00 | 显示全部楼层
[WEB]http://www.mccad.net/object/acad2004/idh_offset.htm[/WEB]
GMT+8, 2025-5-4 13:46 , Processed in 0.143169 second(s), 23 queries , Gzip On.
