查看: 2596|回复: 2
救急啊!!!!
发表于 2002-4-27 11:08:00 | 显示全部楼层 |阅读模式
请问各位大侠
    怎样用VBA把已经插入的块的属性提取出来?例如,提出出来,用msgbox显示。
    请各位指点迷津。谢谢
发表于 2002-4-27 16:03:00 | 显示全部楼层
试试这段程序
Sub ShowBlockAttrib()
    Dim N, M, b As Integer
    Dim AttStr As String
    Dim Attrefs As Variant
    AttStr = ""
'定义选择集
    Dim sset As AcadSelectionSet
    Set sset = ThisDrawing.SelectionSets.Add("SS3")
    sset.SelectOnScreen
'在选择集中找属性
    Dim Entry As AcadEntity
    For Each Entry In sset
        If Entry.ObjectName = "AcDbBlockReference" and Entry.HasAttributes Then
            AttStr = AttStr + Entry.Name + "图块中的属性有:" + Chr(13)
            Attrefs = Entry.GetAttributes
            For M = LBound(Attrefs) To UBound(Attrefs)
                AttStr = AttStr + Attrefs(M).TagString + " = " + Attrefs(M).TextString + Chr(13)
            Next M
            AttStr = AttStr + Chr(13)
        End If
    Next Entry
'显示
    b = MsgBox(AttStr)
'删除选择集
    sset.Delete
End Sub
 楼主| 发表于 2002-4-27 16:15:00 | 显示全部楼层
Thanks!
多谢
让我试试
GMT+8, 2025-6-2 06:11 , Processed in 0.162864 second(s), 25 queries , Gzip On.
