查看: 1414|回复: 2
过滤选择的方法请教
发表于 2006-4-9 21:57:00 | 显示全部楼层 |阅读模式
本人想请教一个只选择圆的方法,下面画绿线处就是
但运行出错,如大师明白为什么错,请多多指教
Public Sub c(layerr As String)
Dim ssetobj1 As AcadSelectionSet
Dim icount1 As Integer
icount1 = ThisDrawing.SelectionSets.Count
While (icount1 > 0)
    If ThisDrawing.SelectionSets.Item(icount1 - 1).Name = "yuan" Then
    ThisDrawing.SelectionSets.Item(icount1 - 1).Delete
    End If
    icount1 = icount1 - 1
    Wend
    Set ssetobj1 = ThisDrawing.SelectionSets.Add("yuan")
    ThisDrawing.Utility.Prompt "please select object"
    dim filtertype as integer
    dim filterdata as string
    filtertype = 0
   filterdata=" circle "
    ssetobj1.SelectOnScreen filtertype,filterdata
  Dim i1 As Integer
  Dim selobj1 As Acadcircle
  For i1 = 0 To ssetobj1.Count - 1
      Set selobj1 = ssetobj1.Item(i1)
  Next
  End Sub
发表于 2006-4-10 00:11:00 | 显示全部楼层
发表于 2006-4-10 09:02:00 | 显示全部楼层
过滤类型和数据要用数组,不是一个单一的字符串。。。。
GMT+8, 2025-2-21 03:02 , Processed in 0.139402 second(s), 23 queries , Gzip On.
