查看: 1656|回复: 2
ActiveLayout.StyleSheet
发表于 2006-4-13 09:27:00 | 显示全部楼层 |阅读模式
ThisDrawing.ActiveLayout.StyleSheet = "monochrome.ctb"
为什么出错?
 楼主| 发表于 2006-4-13 13:20:00 | 显示全部楼层
Public Sub printdoc()
Dim point1(100) As Variant
Dim point2 As Variant, point3 As Variant, point4(0 To 1) As Variant
Dim keywordList As String
On Error Resume Next
With ThisDrawing.ActiveLayout
.CenterPlot = True
.PlotRotation = ac90degrees
.PaperUnits = acMillimeters
.CanonicalMediaName = "A4"
.ConfigName = "HP LaserJet 5100 Series"
End With
point2 = ThisDrawing.Utility.GetPoint(, vbLf & "请点击打印区域的左下角:")
i = 0
Do While i < 1
  point1(i) = point2
  If Err.Number = -2147352567 Or Err.Number = 13 Then
  Exit Sub
   End If
    point2 = ThisDrawing.Utility.GetPoint(, vbLf & "请点击打印区域的右上角:")
 If (Int(point1(i)(1)) <> Int(point2(1))) Then
  i = i + 1
  point1(i) = point2
  End If
Loop
Number = ThisDrawing.Utility.GetInteger("Enter an number of the pages: ")
point2 = point1(0)
point3 = point1(1)
ReDim Preserve point2(0 To 1)
ReDim Preserve point3(0 To 1)
For j = 0 To Number - 1
point2(0) = point2(0) + (point3(0) - point2(0)) * j
point3(0) = point3(0) + (point3(0) - point2(0)) * j
ThisDrawing.ActiveLayout.CenterPlot = True
ThisDrawing.ActiveLayout.SetWindowToPlot point2, point3
ThisDrawing.Plot.NumberOfCopies = 1
ThisDrawing.ActiveLayout.PlotType = acWindow
ThisDrawing.Plot.DisplayPlotPreview acFullPreview
Next j
End Sub
为什么不能居中打印,还要设什么?
 楼主| 发表于 2006-4-13 13:30:00 | 显示全部楼层
问题解决了
GMT+8, 2025-5-4 15:05 , Processed in 0.185584 second(s), 23 queries , Gzip On.
