查看: 1954|回复: 7
求助各位大侠,请zzxxqq一定进来看看。
发表于 2006-4-23 13:46:00 | 显示全部楼层 |阅读模式
各位大侠,帮帮忙。
以下程序为zzxxqq大侠为本人写的,我想再加些功能。就是在执行中程序能记住上次输入的数值,如果不输入就用默认值来运行。谢谢!!!
(DEFUN C:GTT ()
  (SETvar "CMDECHO" 0)
  (vl-cmdf "_.undo" "_group")
  (SETQ OLDOS (GETvar "OSMODE"))
  (SETvar "OSMODE" 0)
  (command "ucs" "w")
  (setq LANGLST '(("CHS"      "\n输入挂台距离<17.95>:"
     "\n输入挂台宽<3.05>:"    "\n输入挂台深<1.0>:"
     "\n选择一条边:"     "\n起始点:"
     "\n哪一边?:"
    ("CHT"
     "\n块珽禯瞒 <17.95> :"
     "\n块珽糴 <3.05> :"
     "\n块珽瞏 <1.0> :"
     "\n匡拒兵娩 :"
     "\n癣﹍翴:"
     "\n娩?:"
  (setq LST (cdr (assoc (getvar "LOCALE") LANGLST)))
  (SETQ AL1 (/ PI 2)
 GTL (GETDIST (nth 0 LST))
 GTL (IF (= GTL nil)
       17.95
       GTL
 GTW (GETDIST (nth 1 LST))
 GTW (IF (= GTW nil)
       3.05
       GTW
 GTD (GETDIST (nth 2 LST))
 GTD (IF (= GTD nil)
       1.0
       GTD
  (SETvar "BLIPMODE" 0)
  (WHILE (SETQ S1 (ENTSEL (nth 3 LST)))
    (SETvar "OSMODE" 1)
    (IF (SETQ P1 (GETPOINT (nth 4 LST)))
      (PROGN
 (SETvar "OSMODE" 0)
 (SETQ DL  (ENTGET (CAR S1))
       PT1 (CDR (ASSOC 10 DL))
       PT2 (CDR (ASSOC 11 DL))
       P2  (IF (> (DISTANCE PT1 P1) (DISTANCE PT2 P1))
      PT1
      PT2
       ANG (ANGLE P1 P2)
       PT  (GETPOINT P1 (nth 5 LST))
       AN1 (ANGLE P1 PT)
       A1  (- AN1 ANG)
       A1  (IF (AND (> A1 0) (> A1 PI))
      (- A1 PI PI)
      A1
       A1  (IF (AND (< A1 0) (< A1 (- PI)))
      (+ A1 PI PI)
      A1
       A1  (IF (> A1 0)
      (+ ANG AL1)
      (- ANG AL1)
       P3  (POLAR P1 ANG GTL)
       P4  (POLAR P3 A1 GTD)
       P5  (POLAR P3 ANG GTW)
       P6  (POLAR P5 A1 GTD)
 (COMMAND "ERASE" (CAR S1) "")
 (COMMAND "LINE" P1 P3 P4 P6 P5 P2 "")
  (command "ucs" "p")
  (SETvar "OSMODE" OLDOS)
  (vl-cmdf "_.undo" "_end")
  (SETvar "CMDECHO" 1)
  (PRINC)
发表于 2006-4-23 16:29:00 | 显示全部楼层
命令: GTT  (挂台)
 楼主| 发表于 2006-4-23 18:10:00 | 显示全部楼层
谢谢XYP1964大侠!!!
能否给小弟份源码学习学习?请不吝赐教。
发表于 2006-4-23 18:23:00 | 显示全部楼层
程序
 楼主| 发表于 2006-4-23 20:06:00 | 显示全部楼层
多谢ZZXXQQ大侠!!
运行时:命令: gtt ; 错误: 参数类型错误: stringp 17.95
发表于 2006-4-23 22:41:00 | 显示全部楼层
  1. (load "xyp_lib.vlx") ;版本 V.20060314
  2. ;|下载和加载通用函数(可在签名栏直接下载后放到搜索路径下)
  3. 利用以下任何一种方式(首选第一种)即可加载和运行通用函数内的所有子程序:
  4. ★1·在acad.lsp中增加(load"xyp_lib")
  5. ■2·在每个程序内增加(load"xyp_lib")
  6. ■3·在command下,输入(load"xyp_lib")
  7. ■4·在菜单.mnl中增加(load"xyp_lib")
  8. ■5·将xyp_lib.vlx文件直接拽到cad屏幕
  9. [COLOR=red] ★通用函数下载地址:[/COLOR]
  10. [url]http://bbs.mjtd.com/forum.php?mod=viewthread&tid=37554[/url]
  11. |;
  12. ;;; gtt(挂台)
  13. (DEFUN C:GTT ()
  14.   (cmdla0)
  15.   (SETvar "OSMODE" 0)
  16.   (if (null gtl)
  17.     (setq gtl 17.95)
  18.   )
  19.   (if (null GTW)
  20.     (setq GTW 3.05)
  21.   )
  22.   (if (null GTD)
  23.     (setq GTD 1.0)
  24.   )
  25.   (SETQ AL1 (/ PI 2)
  26. GTL (UDIST 7 "" "\n输入挂台距离<直接输入或鼠标点取>" GTL nil)
  27. GTW (UDIST 7 "" "\n输入挂台宽<直接输入或鼠标点取>" GTW nil)
  28. GTD (UDIST 7 "" "\n输入挂台深<直接输入或鼠标点取>" GTD nil)
  29.   )
  30.   (WHILE (SETQ S1 (ENTSEL "\n选择一条边: "))
  31.     (SETvar "OSMODE" 1)
  32.     (IF (SETQ P1 (GETPOINT "\n起始点: "))
  33.       (PROGN
  34. (SETvar "OSMODE" 0)
  35. (SETQ DL  (ENTGET (CAR S1))
  36.        PT1 (CDR (ASSOC 10 DL))
  37.        PT2 (CDR (ASSOC 11 DL))
  38.        P2  (IF (> (DISTANCE PT1 P1) (DISTANCE PT2 P1))
  39.       PT1
  40.       PT2
  41.     )
  42.        ANG (ANGLE P1 P2)
  43.        PT  (GETPOINT P1 "\n哪一边?: ")
  44.        AN1 (ANGLE P1 PT)
  45.        A1  (- AN1 ANG)
  46.        A1  (IF (AND (> A1 0) (> A1 PI))
  47.       (- A1 PI PI)
  48.       A1
  49.     )
  50.        A1  (IF (AND (< A1 0) (< A1 (- PI)))
  51.       (+ A1 PI PI)
  52.       A1
  53.     )
  54.        A1  (IF (> A1 0)
  55.       (+ ANG AL1)
  56.       (- ANG AL1)
  57.     )
  58.        P3  (POLAR P1 ANG GTL)
  59.        P4  (POLAR P3 A1 GTD)
  60.        P5  (POLAR P3 ANG GTW)
  61.        P6  (POLAR P5 A1 GTD)
  62. )
  63. (COMMAND "ERASE" (CAR S1) "")
  64. (xyp-mklaco "挂台" 4)
  65. (COMMAND "LINE" P1 P3 P4 P6 P5 P2 "")
  66.       )
  67.     )
  68.   )
  69.   (command "ucs" "p")
  70.   (cmdla1)
  71. )
  72. (princ"命令: GTT  (挂台)")
  73. (princ)
发表于 2006-4-23 23:15:00 | 显示全部楼层
andyding发表于2006-4-23 20:06:00 多谢ZZXXQQ大侠!! 运行时:命令: gtt ; 错误: 参数类型错误: stringp 17.95
改过的程序:
 楼主| 发表于 2006-4-24 23:46:00 | 显示全部楼层
多谢两位大侠!!!
GMT+8, 2025-9-20 01:40 , Processed in 0.209552 second(s), 27 queries , Gzip On.
