查看: 1828|回复: 2
帮我看一段程序吧
发表于 2006-4-27 17:59:00 | 显示全部楼层 |阅读模式
这段程序为绘制一个圆让后生成面域,但是我调试的时候只能绘出圆  ,到生成面域时出错:"时实错误426".请高人指点,谢谢!
Const pi = 3.1415926
Dim r As Double
Dim Acadapp As AutoCAD.AcadApplication
Private Sub Command4_Click()
Call drwPicture
End Sub
 '绘制面域
 Sub drwPicture()
 Call linkCad
 Dim curves(0) As AutoCAD.AcadEntity
 Dim centerpoint(2) As Double
 r = 600
 centerpoint(0) = 0: centerpoint(1) = 0: centerpoint(2) = 0
  Set curves(0) = Acadapp.ActiveDocument.ModelSpace.AddCircle(centerpoint, r)
  Dim obj As Object
 obj = Acadapp.ActiveDocument.ModelSpace.AddRegion(curves)
 End Sub
'建立与cad连接
Sub linkCad()
On Error Resume Next
  Set Acadapp = GetObject(, " AutoCAD.Application")
  If Err Then
    Err.Clear
    Set Acadapp = CreateObject("AutoCAD.Application")
    If Err Then
      MsgBox Err.Description
      Exit Sub
    End If
  End If
  Acadapp.Visible = True
   Acadapp.WindowState = AutoCAD.AcWindowState.acMax
End Sub
发表于 2006-4-27 18:34:00 | 显示全部楼层
AddRegion函数的返回值是实体数组,而不是Object
 楼主| 发表于 2006-4-27 22:03:00 | 显示全部楼层
要怎么呢?我是新手,谢谢
GMT+8, 2025-5-4 13:48 , Processed in 0.171472 second(s), 23 queries , Gzip On.
