查看: 1493|回复: 2
由多边型选择时,怎么有时候是空的呢?有时候可以
发表于 2006-5-1 11:43:00 | 显示全部楼层 |阅读模式
由多边型选择时,怎么有时候是空的呢?
有时候是空,再重复一边又不是空的
这是为什么????/
发表于 2006-5-3 15:14:00 | 显示全部楼层
看看你的代码?
 楼主| 发表于 2006-5-5 18:19:00 | 显示全部楼层
代码:
PlshuZu = Plbound.Coordinates
 Dim SelectMaph As AcadSelectionSet
             ThisDrawing.SelectionSets("selectmapfull").Delete
             Set SelectMaph = ThisDrawing.SelectionSets.Add("selectmapfull")
             ThisDrawing.SelectionSets("selectmapfull").Clear
             SelectMaph.Clear
                boundPLIn = BoundPl(i).Offset(-0.05)
              If boundPLIn(0).Area > BoundPl(i).Area Then
                boundPLIn(0).Delete
                boundPLIn = BoundPl(i).Offset(0.05)
               End If
             SelectMaph.Update
             SelectMaph.SelectByPolygon acSelectionSetCrossingPolygon, boundPLIn(0).Coordinates
             SelectMaph.Update
             boundPLIn(0).Delete
            ReDim boundPLIn(0 To 0) As AcadEntity
            Set boundPLIn(0) = BoundPl(i)
             SelectMaph.AddItems boundPLIn
             SelectMaph.Update
         Bpoint(0) = PlshuZu(i * 2): Bpoint(1) = PlshuZu(i * 2 + 1)
         Ang = PL_infor(i, 0)
         Call MakeStretch.Copy_Move_rotate(BoundPl(i), SelectMaph, Bpoint, Mpoint, Ang)
还有个问题:我用extrim裁剪时有时候出现:”未找到多段线复制端点“或“对象未与边相交” 是什么意思?
GMT+8, 2025-5-7 20:32 , Processed in 0.141044 second(s), 23 queries , Gzip On.
