查看: 1954|回复: 2
请问真正高手:关于CAD里面选择集过滤器的使用
发表于 2006-5-3 15:30:00 | 显示全部楼层 |阅读模式
Dim sobj As AcadObject
   Dim ssetObj As AcadSelectionSet
  Dim GpCode(0 to 1) As Integer
    Dim DataValue(0 to 1) As Variant
   Set ssetObj = ThisDrawing.SelectionSets.Add("SSET" + CStr(Rnd(1)))
       GpCode(0) = 0
    DataValue(0) = "Line"
       GpCode(1) = 8
    DataValue(1) = "0"
   Mode = acSelectionSetAll
 ssetObj.Select Mode, , , GpCode, DataValue
上面可以选择0图层里面的所有线
怎么选择0图层里面的所有块?
 用以下都不行:
      GpCode(0) = 0
    DataValue(0) = "Block"
or
      GpCode(0) = 0
    DataValue(0) = "BlockRef"
发表于 2006-5-3 19:02:00 | 显示全部楼层
DataValue(0) = "Insert"
发表于 2006-5-15 14:25:00 | 显示全部楼层
雪山飞狐 老大,请问如何将几个不同块名的块添加到一个选择集???
       GpCode(0) = 0
       GpCode(1) = 2
    DataValue(1) = "z1,z2,z3"
上面可以选择块名为z1,z2,z3的所有块
请问:
如何以 OR 的关系分别选择??
 DataValue的值可否为空??
可否用一小结构??
GpCode(1) = -4
 DataValue(1) = "< or"
IF *** THEN
 GpCode(2) = 2
 DataValue(2) = "Z1"
END IF
IF *** THEN
 GpCode(3) = 2
 DataValue(3) = "Z2"
END IF
IF *** THEN
 GpCode(4) = 2
 DataValue(4) = "Z3"
END IF
GpCode(5) = -4
 DataValue(5) = " or >"
GMT+8, 2025-2-19 06:11 , Processed in 0.160335 second(s), 24 queries , Gzip On.
