查看: 1400|回复: 2
[求助]帮看下这段代码
发表于 2006-5-8 12:08:00 | 显示全部楼层 |阅读模式
主要功能是实现,在选中多个布局中的两个文字,在文字下方画线,同时修改颜色和大小
存在问题是,在选择文字时。很多时候选不上文字,但如果只有一个布局时,又可以选择上。多个布局时,很多布局上的选不上。
Sub Example_PaperUnits()
    ' This example will access the Layouts collection for the current drawing
    ' and list basic information about the paper units used for each Layout.
    Dim Layouts As AcadLayouts, Layout As AcadLayout
   Dim ssetObj As AcadSelectionSet
    Dim CONUT As Integer
    Dim FilterType(1) As Integer
   Dim FilterData(1) As Variant
   Dim lend As Variant
   Dim corner1(0 To 2) As Double
    Dim corner2(0 To 2) As Double
      Dim lineObj As AcadLine
    ' Get layouts collection from document object
    Set Layouts = ThisDrawing.Layouts
    For Each Layout In Layouts
    ThisDrawing.SetVariable "CTAB", Layout.Name
    CONUT = 0
    Count = ThisDrawing.SelectionSets.Count
     For i = 0 To Count - 1 '删除所有的选择集
    Set ssetObj = ThisDrawing.SelectionSets.Item(0)
      ssetObj.Delete
    Next i
       ' ThisDrawing.ActiveSpace = acModelSpace
          Set ssetObj = ThisDrawing.SelectionSets.Add("sjx")
          FilterType(0) = 0
          FilterData(0) = "text"
          FilterType(1) = 8
          FilterData(1) = "TK_STA"
          'ssetObj.Select acSelectionSetAll, , , FilterType, FilterData
          ssetObj.Select acSelectionSetCrossing, corner1, corner2, FilterType, FilterData
          For Each entry In ssetObj
          'MsgBox entry.TextString
            lend = entry.TextAlignmentPoint
            corner1(0) = lend(0) + 20 * Cos(entry.Rotation): corner1(1) = lend(1) + 20 * Sin(entry.Rotation)
            corner2(0) = lend(0) + 20 * Cos(entry.Rotation + 3.1415926): corner2(1) = lend(1) + 20 * Sin(entry.Rotation + 3.1415926)
          Set lineObj = ThisDrawing.PaperSpace.AddLine(corner1, corner2)
           lineObj.color = 6
           lineObj.Update
           Count = 4
           entry.Height = Count
           entry.color = 6
           entry.Update
           Next entry
          corner1(0) = 21: corner1(1) = 15: corner1(2) = 0
         corner2(0) = 400: corner2(1) = 260: corner2(2) = 0
    Next
   'ThisDrawing.SetVariable "CTAB", Layout.Name
End Sub
发表于 2006-5-8 14:18:00 | 显示全部楼层
之前怎么没见你给corner1,和corner2赋值?
 楼主| 发表于 2006-5-8 14:30:00 | 显示全部楼层
后边的也不行啊。同一个布局,根本就选不上。不过只要把其他的布局都删了,就可以了。
所有的布局都是一个程序自动生成的,如果你每一个布局都点一个就可以选取上了。要不一直是选取不上的。不知道如果解决。
GMT+8, 2025-5-4 12:26 , Processed in 0.145694 second(s), 22 queries , Gzip On.
