查看: 1741|回复: 4
急急急~~!怎么样点击图形,弹出对话框窗体来输入参数!~~~
发表于 2006-5-12 23:58:00 | 显示全部楼层 |阅读模式
我通过输入参数的窗体输入参数,然后画了一个图形,画完图,我怎么在次点击图的时候在次让它弹出参数窗体,然后我可以从新输入参数,来从新画图,或者改变图的大小??
 楼主| 发表于 2006-5-13 00:14:00 | 显示全部楼层
Option Explicit
'定义图形的12条边界线
Global lineobject(0 To 11) As AcadLine
'定义图形面域
Global regionobject As Variant
 '定义图形拉伸后的实体
Global solidobject As Acad3DSolid
'定义图形的宽度、高度和厚度等参数
Global beamwidth As Double
Global beamheight As Double
Global beamwebthickness As Double
Global solidlength As Double
Global beammi As Double
Global beamsectmod As Double
Global beamexists As Boolean
Global buffblock As AcadBlock
Public Sub createibeam(width As Double, height As Double, webthickness As Double, solcdlength As Double)
   definebeam width, height, webthickness
   regionobject = buffblock.AddRegion(lineobject)
   Set solidobject = ThisDrawing.ModelSpace.AddExtrudedSolid(regionobject(0), solidlength, 0)
   beamexists = True
   Dim vportobj As Object
   Set vportobj = ThisDrawing.Viewports.Add("IBEAMVIEWPORT")
   ThisDrawing.ActiveViewport = vportobj
   Dim newdirection(0 To 2) As Double
       newdirection(0) = 1#
       newdirection(1) = -1#
       newdirection(2) = 1#
    vportobj.Direction = newdirection
End Sub
Public Function checkrules(width As Double, height As Double, webthickness As Double) As Boolean
    Dim webheight As Double
       If (width > 0) And (height > 0) And (webthickness > 0) Then
           webheight = height - 2 * webthickness
              If webheight <= 0 Then
                  Exit Function
              End If
              If (width > webthickness) And (height > webheight) And (webthickness >= width / 6) And (webheight >= width / 4) Then
              checkrules = True
              End If
       End If
End Function
Sub IBEAMVBA()
   UserForm1.Show
End Sub
Private Sub definebeam(width As Double, height As Double, webthickness As Double)
   Dim x(0 To 11) As Double
   Dim y(0 To 11) As Double
   Dim z As Double
      z = 0
   Dim halfflange As Double
      halfflange = (width - webthickness) / 2
   Dim halfht As Double
      halfht = height - 2 * webthickness
     x(0) = 0
     y(0) = 0
     x(1) = x(0) + width
     y(1) = y(0)
     x(2) = x(1)
     y(2) = y(1) + webthickness
     x(3) = x(2) - halfflange
     y(3) = y(2)
     x(4) = x(3)
     y(4) = y(3) + halfht
     x(5) = x(2)
     y(5) = y(4)
     x(6) = x(5)
     y(6) = y(5) + webthickness
     x(7) = x(0)
     y(7) = y(6)
     x(8) = x(0)
     y(8) = y(5)
     x(9) = x(8) + halfflange
     y(9) = y(4)
     x(10) = x(9)
     y(10) = y(2)
     x(11) = x(0)
     y(11) = y(2)
  Dim inspt(0 To 2) As Double
      inspt(0) = 0
      inspt(1) = 0
      inspt(2) = 0
  Set buffblock = ThisDrawing.Blocks.Add(inspt, "buffblock")
  Dim startpoint(0 To 2) As Double
  Dim endpoint(0 To 2) As Double
  Dim i As Integer
  Dim j As Integer
  For i = 0 To 11
      startpoint(0) = x(i)
      startpoint(1) = y(i)
      startpoint(2) = 0
        j = i + 1
          If i = 11 Then
             j = 0
          End If
          endpoint(0) = x(j)
          endpoint(1) = y(j)
          endpoint(2) = 0
            If beamexists Then
               lineobject(i).startpoint = startpoint
               lineobject(i).endpoint = endpoint
            Else
               Set lineobject(i) = buffblock.AddLine(startpoint, endpoint)
            End If
   Next
End Sub
Public Sub updatabeam(width As Double, height As Double, webthickness As Double, solidlength As Double)
    regionobject(0).Erase
    solidobject.Erase
    Set solidobject = ThisDrawing.ModelSpace.AddExtrudedSolid(regionobject(0), solidlenght, 0)
       ThisDrawing.ActiveViewport.ZoomExtents
       beamexists = True
End Sub
Public Function momentofinteria(width As Double, height As Double, webthickness As Double) As Double
     Dim webht As Double
         webht = height - 2 * webthickness
         momentofinteria = (width * height * height - webthickness * webht * webht * webht) / 12
End Function
Public Function sectionmodulus(width As Double, height As Double, webthickness As Double) As Double
   Dim mi As Double
       mi = momentofinteria(width, height, webthickness)
       sectionmodulus = (mi * 12) / (6 * height)
End Function
这是模块里的程序
 楼主| 发表于 2006-5-13 00:16:00 | 显示全部楼层
'Sub rotate_3Dbox()
'   Dim boxobj As Acad3DSolid
'   Dim length As Double
'   Dim width As Double
'   Dim height As Double
'   Dim center(0 To 2) As Double
'   center(0) = 5
'   center(1) = 5
'   center(2) = 0
'   length = 5
'   width = 7
'   height = 9
'   Set boxobj = ThisDrawing.ModelSpace.AddBox(center, length, width, height)
'End Sub
Option Explicit
Private Sub cmdcreatebeam_Click()
   beamwidth = Scrlwidth.Value
   beamheight = Scrlheight.Value
   beamwebthickness = Scrlthickness.Value
   solidlength = scrllength.Value
   If checkrules(beamwidth, beamheight, beamwebthickness) Then
      createibeam beamwidth, beamheight, beamwebthickness, solidlength
      updatamomentandsection beamwidth, beamheight, beamwebthickness
   Else
      MsgBox "sorry,the beam cannot be created with your settings.", vbExclamation
  If Not (beamexists) Then
     MsgBox "defult setting restored.", vbInformation
    Scrlwidth.Value = 650
    Scrlheight.Value = 650
    Scrlthickness.Value = 125
    scrllength.Value = 200
  End If
End If
End Sub
Private Sub cmdquit_Click()
    Unload Me
End Sub
Private Sub Label8_Click()
End Sub
Private Sub Scrlheight_Change()
   If beamexists = True Then
      If checkrules(beamwidth, Scrlheight.Value, beamwebthickness) Then
         updatabeam beamwidth, beamheight, beamwebthickness, solidlength
      Else
        Scrlheight.Value = beamheight
      End If
   End If
End Sub
Private Sub scrllength_Change()
  If beamexists Then
  End If
End Sub
Private Sub Scrlthickness_Change()
    If beamexists Then
       If checkrules(beamwidth, beamheight, Scrlthickness.Value) Then
       Else
         Scrlthickness.Value = beamwebthickness
       End If
    End If
End Sub
Private Sub Scrlwidth_Change()
     If beamexists Then
         If checkrules(Scrlwidth.Value, beamheight, beamwebthickness) Then
       Else
           Scrlwidth.Value = beamwidth
         End If
     End If
End Sub
Private Sub UserForm_Click()
End Sub
Private Sub UserForm_Initialize()
End Sub
Private Sub updatamomentandsection(beamwidth#, beamheight#, beamwebthickness#)
   beammi = momentofinteria(beamwidth, beamheight, beamwebthickness)
   beamsectmod = sectionmodulus(beamwidth, beamheight, beamwebthickness)
   Label8.Caption = Format(beammi, "0.0000E+00")
   Label7.Caption = Format(beamsectmod, "0.0000E+00")
End Sub
Private Sub UserForm_Terminate()
   Set solidobject = Nothing
   Dim entry As Object
   For Each entry In ThisDrawing.Blocks
       If entry.Name = "BUFFBLOCK" Then
            buffblock.Delete
        End If
    Next
    beamexists = False
End Sub
这是窗体程序,现在的问题就是想点击画的图就弹出窗体
发表于 2006-5-13 08:41:00 | 显示全部楼层
通过窗体的ObjectModified事件来做。。。
 楼主| 发表于 2006-5-13 13:25:00 | 显示全部楼层
ObjectModified事件?????你能说的详细点么??我以前没有没有接触过这个时间~~~我上面发的有代码,ObjectModified事件加在哪呢?怎么加,先谢谢了~~~
GMT+8, 2025-5-4 14:43 , Processed in 0.161692 second(s), 23 queries , Gzip On.
