查看: 1440|回复: 0
在VB中写CAD二次开发程序,困难 大呀,谁能帮忙解决这个问题
发表于 2006-5-13 17:25:00 | 显示全部楼层 |阅读模式
Private Sub Command1_Click()
Dim Pt1(0 To 2) As Double
Dim Pt2(0 To 2) As Double
On Error Resume Next
    ' 连接至 AutoCAD 应用程序
    Dim acadApp As AcadApplication
    Set acadApp = GetObject(, "AutoCAD.Application.16")
    If Err Then
        Err.Clear
        Set acadApp = CreateObject("AutoCAD.Application.16")
        If Err Then
            MsgBox Err.Description
            Exit Sub
        End If
    End If
    ' 连接至 AutoCAD 图形
    Dim acadDoc As AcadDocument
    Set acadDoc = acadApp.ActiveDocument
Dim ptpick5 As Variant
Dim ptpick6 As Variant
    ptpick5 = acadDoc.ModelSpace.Utility.GetPoint(, "请拾取第一点吊点位置:")
    ptpick6 = acadDoc.ModelSpace.Utility.GetPoint(, "请拾取第二点吊点位置:")
    Pt1(0) = ptpick5(0)
    Pt1(1) = ptpick5(1)
    Pt1(2) = 0
    Pt2(0) = ptpick6(0)
    Pt2(1) = ptpick6(1)
    Pt2(2) = 0
Set plineobj = acadDoc.ModelSpace.AddLine(Pt1, Pt2)
ZoomAll
 acadApp.Visible = True
End Sub
以上代吗   不能和CAD进行交互,在VBA中可以,谁能帮忙在VB中实现同样的功能?谢谢
GMT+8, 2025-5-4 15:29 , Processed in 0.148367 second(s), 23 queries , Gzip On.
