查看: 2205|回复: 7
添加线型
发表于 2006-5-14 18:41:00 | 显示全部楼层 |阅读模式
请教如何用lisp添加acad.lin中的全部线型?谢谢!
发表于 2006-5-14 20:27:00 | 显示全部楼层
程序:
  1. (DEFUN C:LOADLTYPE ()
  2. (SETVAR "CMDECHO" 0)
  3. (IF (SETQ NM (FINDFILE "ACAD.LIN")) (PROGN
  4.   (SETQ F (OPEN NM "r") LINET '())
  5.   (WHILE (SETQ TXT (READ-LINE F))
  6.    (IF (= (SUBSTR TXT 1 1) "*") (PROGN
  7.     (SETQ I 2)
  8.     (WHILE (/= (SUBSTR TXT I 1) ",") (SETQ I (1+ I)))
  9.     (SETQ LINET (CONS (SUBSTR TXT 2 (- I 2)) LINET))
  10.    ))
  11.   )
  12.   (CLOSE F)
  13.   (SETQ LINET (REVERSE LINET))
  14.   (SETQ I -1)
  15.   (COMMAND "LINETYPE")
  16.   (REPEAT (LENGTH LINET)
  17.    (COMMAND "L" (NTH (SETQ I (1+ I)) LINET) "")
  18.   )
  19.   (COMMAND "")
  20. ))
  21. (PRINC)
  22. )
复制代码
发表于 2006-5-15 09:14:00 | 显示全部楼层
(defun C:TT (/ HOLDECHO)
  (setvar "nomutt" 1)
  (setq HOLDECHO (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (command "_.LINETYPE" "L" "*" (findfile "ACAD.LIN"))
  (while (= 1 (getvar "cmdactive"))
    (command "")
  (setvar "nomutt" 0)
  (setvar "cmdecho" HOLDECHO)
发表于 2006-5-16 12:58:00 | 显示全部楼层
"entmake"可以办到吗?
发表于 2006-5-16 20:07:00 | 显示全部楼层
entmake和entmod只能生成和修改实体.不能修改符号表
发表于 2009-6-11 09:59:00 | 显示全部楼层
(entmake (list '(0 . "LTYPE") '(100 . "AcDbSymbolTableRecord") '
        (100 . "AcDbLinetypeTableRecord") '(2 . "FFP") '(70 . 0) '
        (3 . "FIRE_FEEDER_PIPING ---- FFP -------- FFP ------") '
        (72 . 65) '(73 . 3) '(40 . 2.81) '(49 . 2.16) '(74 . 0) '
        (49 . -0.2) '(74 . 0) '(74 . 2) '(75 . 0) (cons 340 (tblobjname "STYLE" "Simplex"))
         '(46 . 0.2) '
        (50 . 0.0) '(44 . -0.1) '(45 . -0.09) '(9 . "FFP") '
        (49 . -0.45) '(74 . 0)
  )          ; list
发表于 2013-1-29 15:05:21 | 显示全部楼层
(340)组码不正确。
发表于 2013-1-29 15:23:30 | 显示全部楼层
不能用,楼主能不能给个带说明的。
GMT+8, 2025-7-20 12:48 , Processed in 0.190145 second(s), 25 queries , Gzip On.
