查看: 4007|回复: 11
[求助]大侠:请教VB调用自定义函数的值传递问题
发表于 2006-5-14 22:35:00 | 显示全部楼层 |阅读模式
我在编一个求点集凸包的程序
采点集的程序部分已经搞定
想把点集中y最近小且距x最远的点找到,就用二分法排了序,但数组p()的值纵传不到数组pl()上。请在帮忙看下:
Option Explicit
Private Type pointinfo
x As Single                    '
点的x 坐标值
y As Single                    '点的y 坐标值
q As Single                    '与水平线的夹角
End Type
Dim p0 As pointinfo
Dim p(0 To 200) As pointinfo    '
点集
Dim pl(0 To 200) As pointinfo   '求出起始点
Dim ps(0 To 200) As pointinfo   '排序后的点集
Dim pi(0 To 200) As pointinfo   '极点
Dim n, m, d As Integer
Dim x0, y0 As Single
Dim l, e As Integer
Private Sub Form_MouseDown(Button As Integer, Shift As Integer, x As Single, y As Single)
DrawWidth = 4
If n = 0 Then
 p(0).x = x
 p(0).y = y
 Circle (x, y), 100, RGB(255, 0, 255)
Else '
输入点集
 p(n).x = x
 p(n).y = y
 Circle (x, y), 10, RGB(255, 255, 0)
End If
n = n + 1
x0 = x
y0 = y
End Sub
Private Sub Command2_Click()
Dim i As Integer
Dim q As Single
p(n).x = x0
p(n).y = y0
Const pi = 3.14
Dim u, j As Integer
Dim k, r, f As Integer
Dim term As pointinfo
For u = 0 To n
  term = p(l)
  k = 0
  r = u - 0
  Do While k <= r
           f = Int((k + r) / 2)
          If term.y < pl(f).y Or (term.y = pl(f).y And (Abs(term.x) > Abs(pl(f).x))) Then
             r = f - 1
          Else
             k = f + 1
          End If
  Loop
  For j = u - 1 To k Step -1
      pl(j + 1) = pl(j)
  Next j
  pl(k) = term
Next u
End Sub
发表于 2006-5-15 09:20:00 | 显示全部楼层
呵呵!昨天公司休息,没有电脑能上网啊。。。。
dance,不怕你见笑,二分法我不明白。。。。要是我做,如果只是简单得到Y最
小X最大的数组,在command2的点击事件中这么写:
Dim i As Integer
term.x = p(0).x: term.y = p(0).y
For i = 1 To n - 1
   If p(i).y < term.y Or (p(i).y = term.y And p(i).x > term.x) Then
        term.x = p(i).x: term.y = p(i).y
    end if
Next
End Sub
发表于 2006-5-15 09:43:00 | 显示全部楼层
如果是排序,我这样写的:
Dim i As Integer, j As Integer
For i = 1 To n - 1
    For j = 1 To n - i
        If p(j).y < p(j - 1).y Or (p(j).y = p(j - 1).y And p(j).x > p(j - 1).x) Then
            term.x = p(j - 1).x: term.y = p(j - 1).y
            p(j - 1).x = p(j).x: p(j - 1).y = p(j).y
            p(j).x = term.x: p(j).y = term.y
        End If
    Next
Next
End Sub
 楼主| 发表于 2006-5-15 22:17:00 | 显示全部楼层
[求助]
xinghesnak发表于2006-5-15 9:43:00 如果是排序,我这样写的: Private Sub Command2_Click()Dim i As Integer, j As IntegerDim term As pointinfoFor i = 1 To n ...
呵呵,这个方法很奏效.谢谢.
为了从p(0)开始计点,我把form-click()部分给改写了下。
但是我在往下编写求其他各点与排序后的极植点p(0)所在水平线的角度p(i).q时,又出现了值传递问题。p(i).q的值总是0,而不是程序的计算值。下面是我的程序:
Option Explicit
x As Single                    '点的x 坐标值
End Type
Dim p0 As pointinfo
Dim p(0 To 200) As pointinfo    '点集
Dim l, e As Integer
DrawWidth = 4
If n = 0 Then
 p(0).x = x
 p(0).y = y
Else '输入点集
 p(n).x = x
 p(n).y = y
End If
n = n + 1       '我后改写的部分
End Sub
Dim i As Integer
Dim q As Single
Const pi = 3.14
Dim u As Integer, j As Integer                           '将p()排序y有小至大。
For u = 1 To n - 1
    For j = 1 To n - u
        If p(j).y < p(j - 1).y Or (p(j).y = p(j - 1).y And p(j).x < p(j - 1).x) Then
        End If
    Next j
Next u
For i = 1 To n - 1                                         '我计算角度的程序
If p(i).y - p(0).y = 0 Then
        If p(i).x - p(0).x = 0 Then
           p(i).q = 90
        ElseIf p(i).x - p(0).x > 0 Then
          p(i).q = 180 / pi * Atn((p(i).y - p(0).y) / (p(i).x - p(0).x))
        Else
            p(i).q = 180 / pi * Atn((p(i).y - p(0).y) / (p(i).x - p(0).x)) + 180
        End If
ElseIf p(i).y - p(0).y < 0 Then
           p(i).q = 270
          p(i).q = 360 + 180 / pi * Atn((p(i).y - p(0).y) / (p(i).x - p(0).x))
        Else
          p(i).q = 180 + 180 / pi * Atn((p(i).y - p(0).y) / (p(i).x - p(0).x))
        End If
End If
Next i
End Sub
发表于 2006-5-16 09:19:00 | 显示全部楼层
楼上的,你的程序可。。。。。。
If p(i).y - p(0).y = 0 Then 这句话是不是你的笔误啊,应该写成
If p(i).y - p(0).y> =0 Then ??
 楼主| 发表于 2006-5-17 15:38:00 | 显示全部楼层
[求助]
xinghesnak发表于2006-5-16 9:19:00 楼上的,你的程序可。。。。。。
呵呵,你是不是觉得俺的程序有点啰嗦
不好意思,总是边着编着出纰漏。
 楼主| 发表于 2006-5-17 15:43:00 | 显示全部楼层
[求助]
我现在请问下,怎么清除一个自定义数组的一个值?
下面是后续程序
Private Sub Command3_Click()
Dim u As Integer, j As Integer                           '将p()排序q有小至大逆时针排序。
For u = 1 To n - 1
    For j = 1 To n - u
        If p(j).q < p(j - 1).q Or (p(j).q = p(j - 1).q And p(j).y < p(j - 1).y) Then
            term = p(j - 1)
            p(j - 1) = p(j)
            p(j) = term
        End If
    Next j
Next u
End Sub
Private Sub Command4_Click()
'找极点
Dim i, j As Integer
Dim s As Single
Dim inpv As Integer
pi(0) = p(0)
pi(1) = p(1)
m = 1
For d = 2 To n - 1
s = sarea(pi(m - 1), pi(m), p(d))
 If s > 0 Then                 '点在pv 数组尾的左侧
    pi(m + 1) = p(d)
    m = m + 1
 Else:
    pi(m) = p(d)               '点在pv 数组尾的右边侧
    m = m - 1
 End If
     m = m + 1
Next d
If s = sarea(pi(m - 1), pi(m), p(0)) < 0 Then
   pi(m).x = "": pi(m).y = "": pi(m).q = ""          ‘我想在这个位置清除pi(m)。但怎么设都不行
   m = m - 1
End If
DrawWidth = 2
For j = 0 To n - 1          '输出极边
Line (pi(j).x, pi(j).y)-(pi(j + 1).x, pi(j + 1).y)
Next j
Line (pi(n).x, pi(n).y)-(pi(0).x, pi(0).y)
End Sub
 楼主| 发表于 2006-5-17 15:46:00 | 显示全部楼层
抱歉,刚刚忘打自定义函数了
Private Function sarea(x As pointinfo, y As pointinfo, z As pointinfo) As Single
sarea = (x.x * y.y - x.y * y.x) + (y.x * z.y - y.y * z.x) + (z.x * x.y - z.y * x.x)
End Function
发表于 2006-5-17 16:26:00 | 显示全部楼层
清楚P(m)是什么意思?除掉这个数还是清除里面的数据?
 楼主| 发表于 2006-5-17 20:34:00 | 显示全部楼层
[求助]
xinghesnak发表于2006-5-17 16:26:00清楚P(m)是什么意思?除掉这个数还是清除里面的数据?
End Type
p(m)为其中的一个值
GMT+8, 2025-5-25 06:33 , Processed in 0.195550 second(s), 24 queries , Gzip On.
