查看: 1992|回复: 2
大家看看打印程序哪儿出错了?
发表于 2006-5-19 19:10:00 | 显示全部楼层 |阅读模式
每次运行程序(vba) 只能打一张图然后弹出错误框:
 Option Explicit
    Sub tt()
    Dim fn As String
    Dim strpath As String
    Dim doc As AcadDocument
    Dim docs As AcadDocuments
    Dim mdl As AcadModelSpace
    Dim plt As AcadPlot
    Dim dl(1) As Double, ur(1) As Double
    dl(0) = 443.2937: dl(1) = 203.4134
    ur(0) = 708.265: ur(1) = 522.5616
    strpath = "E:\重要工程\控制\控制点点之记\123\"
    Dim filname As String, dirf() As String
    Dim i As Integer, j As Integer
    filname = Dir(strpath + "*.dwg")
    i = 1
    Do While filname <> ""
       ReDim Preserve dirf(1 To i) As String
       dirf(i) = strpath + filname
       filname = Dir
       i = i + 1
    Loop
    j = UBound(dirf)
    Set docs = ThisDrawing.Application.Documents
    For i = 1 To j
       Set doc = docs.Open(dirf(i))
       ThisDrawing.Application.ZoomExtents
       Set mdl = doc.ModelSpace
       With mdl.Layout
            .ConfigName = "hp LaserJet 1320 PCL 6"
            .StandardScale = acScaleToFit
            .PlotRotation = ac0degrees
            .SetWindowToPlot dl, ur
            .PlotType = acWindow
            .CenterPlot = True
       End With
      ' On Error Resume Next
      doc.Plot.PlotToDevice
      doc.Close False
    Next i
    MsgBox "finish", vbOKOnly, "OK"
 End Sub
发表于 2006-5-19 20:26:00 | 显示全部楼层
设置系统变量BACKGROUNDPLOT
发表于 2006-5-19 22:17:00 | 显示全部楼层
lgf727说得对,将Backgroundplot变量设为0即可。关于这一点,我一直没明白,为什么Autodesk做成这个样子。
GMT+8, 2025-8-30 04:38 , Processed in 0.177098 second(s), 24 queries , Gzip On.
