查看: 3340|回复: 2
[求助]怎么用VB在CAD中图案填充呀
发表于 2006-5-25 16:47:00 | 显示全部楼层 |阅读模式
    哪位大哥帮帮忙,小弟做毕业设计急用.
 如何用VB ActiveX技术实现CAD中的图案填充呀
   另外,在CAD中用VB能不能实现图形的打断?
发表于 2006-5-29 20:25:00 | 显示全部楼层
    我也 是刚学的,从明经通道出的书上看的一点点 上面有图案填充源代码,摘录下来让你看看,我试过可行
'创建渐变填充
'patType:0为预定义图案,1为用户定义图案
'patName:包括LINEAR, CYLINDER, INVCYLINDER, SPHERICAL HEMISPHERICAL, CURVED, INVSPHERICAL, INVHEMISPHERICAL和INVCURVED
Public Function AddHatchGC(ByRef objList() As AcadEntity, ByVal patType As Integer, ByVal patName As String, _
    ByVal associativity As Boolean, ByVal color1 As AcadAcCmColor, ByVal color2 As AcadAcCmColor) As AcadHatch
    On Error GoTo errHandle
    '定义填充对象
    Dim objHatch As AcadHatch
    Set objHatch = ThisDrawing.ModelSpace.AddHatch(patType, patName, True, acGradientObject)
    objHatch.GradientColor1 = color1
    objHatch.GradientColor2 = color2
    objHatch.AppendOuterLoop (objList)
    objHatch.Evaluate
    ThisDrawing.Regen True
    Set AddHatchGC = objHatch
    Exit Function
errHandle:
    If Err.Number = -2145386493 Then
        MsgBox "填充定义边界未闭合!", vbCritical
    End If
    Err.Clear
End Function
'创建真彩色填充
Public Function AddHatchTC(ByRef objList() As AcadEntity, ByVal patType As Integer, _
    ByVal associativity As Boolean, ByVal color As AcadAcCmColor) As AcadHatch
    '定义填充对象
    Set objHatch = ThisDrawing.ModelSpace.AddHatch(patType, "LINEAR", True, acGradientObject)
    objHatch.Evaluate
    Set AddHatchTC = objHatch
    Exit Function
errHandle:
    End If
    Err.Clear
End Function
'直接根据X、Y方向增量移动实体
Public Function MoveEntity(ByVal objEntity As AcadEntity, ByVal x As Double, ByVal y As Double, _
    Optional z As Double = 0)
    Dim ptBase(2) As Double
    Dim ptDest(2) As Double
    '基点和目标点的位置
    ptBase(0) = 0: ptBase(1) = 0: ptBase(2) = 0
    ptDest(0) = x: ptDest(1) = y: ptDest(2) = z
    objEntity.Move ptBase, ptDest
End Function
'复制对象,并将复制得到的对象移动一定的位置
Public Function CopyEntity(ByVal objEntity As AcadEntity, ByVal x As Double, ByVal y As Double, _
    Optional z As Double = 0) As AcadEntity
    Dim objCopy As AcadEntity
    '基点和目标点的位置
    Set objCopy = objEntity.Copy
    objCopy.Move ptBase, ptDest
    Set CopyEntity = objCopy
End Function
'创建渐变填充
    '定义填充对象
    objHatch.Evaluate
    Exit Function
errHandle:
    End If
    Err.Clear
End Function
'创建真彩色填充
    '定义填充对象
    objHatch.Evaluate
    Exit Function
errHandle:
    End If
    Err.Clear
End Function
'直接根据X、Y方向增量移动实体
    '基点和目标点的位置
End Function
    '基点和目标点的位置
End Function
GMT+8, 2025-8-30 04:39 , Processed in 0.149121 second(s), 25 queries , Gzip On.
