查看: 2803|回复: 2
获得AutoCAD应用程序窗口的句柄
发表于 2006-5-29 18:02:00 | 显示全部楼层 |阅读模式
[转载]获得AutoCAD应用程序窗口的句柄
Attribute VB_Name = "GetAcadHwnd" 'Purpose ' Returns the handle to the AutoCAD application window 'Notes ' Use this when you need a handle to AutoCAD's main window rather than a document window
Public Declare Function GetParent Lib "user32" (ByVal hwnd As Long) As Long
Public Function GetAcadHwnd() As Long
GetAcadHwnd = GetParent(GetParent(ThisDrawing.hwnd))
End Function
哪位xd能帮解释一下ThisDrawing具体是个什么,是个autocad文件还是其它什么。
发表于 2007-1-17 18:54:00 | 显示全部楼层
VBA中ThisDrawing是指的当前文档.
发表于 2008-7-18 18:02:00 | 显示全部楼层
这里应该用acadApp.Activedocument代替
GMT+8, 2025-4-5 05:40 , Processed in 0.135574 second(s), 25 queries , Gzip On.
