查看: 2564|回复: 2
安装AIP10或AIP11时遇到“错误1406”的解决办法
发表于 2006-5-30 10:10:00 | 显示全部楼层 |阅读模式
在安装AIP10或AIP11时,可能会遇到“错误1406”的对话框,解决办法如下:
进入“控制面板>添加/删除程序”,卸载Macromedia Flash Player 8,然后点击“重试”按钮。
发表于 2006-5-30 12:04:00 | 显示全部楼层
奇怪,居然卸載不了.
发表于 2006-5-30 12:53:00 | 显示全部楼层
楼主说的不完整,是这样的:
Cancel the installation of Autodesk Inventor.
Close all Internet Explorer browser windows and any other internet browser windows you have open.
On the Start menu (Windows), click Run.
In the Run dialog box, enter C:\WINDOWS\system32\Macromed\Flash\UninstFl.exe to clean all Flash 8a registries. Note: Make sure to enter the entire path.
On the Start menu (Windows), click Settings > Control Panel.
In Control Panel, double-click Add or Remove Programs.
In the Add or Remove Programs dialog box, select Macromedia Flash Player 8. Click Remove. Note: Although Flash Player 8 is listed, this is really version 8a.
Retry installation of Autodesk Inventor.
If you are still not able to install Autodesk Inventor successfully, please contact Product Support for further assistance.
GMT+8, 2025-8-11 09:48 , Processed in 0.163097 second(s), 25 queries , Gzip On.
