查看: 1339|回复: 2
急急求助~~ 还望各位大侠们多多指导~~
发表于 2006-6-12 16:06:00 | 显示全部楼层 |阅读模式
我画了一个圆弧
想更改它的起始端点与中止端点
查找圆弧的属性时,表明它的起始端点与中止端点分别为StartPoint  与EndPoint,而且是可编辑的
可是 为什么我一对它赋值,他就出现错误
而且这种错误也只在我要给点赋值时才出现,像  我对它的圆心赋值也出现错误,但是我对  它的起始角度赋值时就没错
求助~~~~   我要怎样对一个点赋值呢???
发表于 2006-6-12 21:34:00 | 显示全部楼层
Specifies the start point for the arc, line, or ellipse.
MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/startpoint_see_also.htm" target="_blank" >See Also | MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/ex_startpoint.htm" target="_blank" >Example
Signature
object.StartPoint
object
MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_arc_object.htm" target="_blank" >Arc, MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_ellipse_object.htm" target="_blank" >Ellipse, MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_line_object.htm" target="_blank" >Line
The object or objects this property applies to.
StartPoint
Variant (three-element array of doubles);
For the Arc and Ellipse objects this property is read-only.
For the Line object this property is read-write.
The 3D WCS coordinate representing the start point for the object.
Remarks
The start point for an arc, ellipse, and line
[U]You cannot change the start point of an arc or ellipse[/U]. To edit an arc, use the MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_endangle.htm" target="_blank" >EndAngle and MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_radius.htm" target="_blank" >Radius properties. To edit an ellipse, use the EndAngle, MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_majoraxis.htm" target="_blank" >MajorAxis, and MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_radiusratio.htm" target="_blank" >RadiusRatio properties.
所以说是可编辑的是错误的
发表于 2006-6-12 22:41:00 | 显示全部楼层
把点转换为对应的角度-〉修改角度
GMT+8, 2025-8-30 02:58 , Processed in 0.179762 second(s), 25 queries , Gzip On.
