查看: 3381|回复: 3
如何保存自定义类绘制的实体?
发表于 2002-4-29 10:00:00 | 显示全部楼层 |阅读模式
我自己开发了一个公路类,3条直线,可是绘制的图形无法保存,请高手指点!
//类的头文件.h
#ifndef __ROADCLASS__H__
#define __ROADCLASS__H__
#include "dbents.h"
class Road
        private:
                AcGePoint3d g3Sp,g3Ep;//公路的起点和终点
                double dBlg;//公路的突起值
                double dWRd;//公路的宽度
                int iClrRd;//公路颜色
                AcDbObjectId idMiddle,idLift,idRight;//三条中线的id
        public:
                Road();
                Road(AcGePoint3d g3StartPt,AcGePoint3d g3EndPt,
                        int iRoadColor,
                        double dBulge,double dWidthRoad);
                ~Road();
                void drawRoad();
};  //自定义类结束
#endif
//类的实现文件.cpp
#include "stdafx.h"
#include "croadclass.h"
#include "dbproxy.h"
/***  fast_changEntityColor        2k1                     ***/
/***  功能描述:改变实体的颜色                             ***/
/*** 入口参数:AcDbEntity * x_pEntity                      ***/
/***            int x_color                                ***/
/***  返回值:  void                                       ***/
/***  Programmed by Wang Zhiqin, 2001.08.01                ***/
void fast_changEntityColor(AcDbEntity * x_pEntity,int x_color)
        AcCmColor color;
        color.setColorIndex(x_color);
        x_pEntity->setColor(color);
/***            fast_Entity_addToDb       arx2000           ***/
/***  功能描述:把新创建的实体加入数据库                   ***/
/***  入口参数:AcDbLine * pEntity, AcDbObjectId& id       ***/
/***  返回值: 0: 失败;1:成功;                          ***/
/***            int                                        ***/
/***  Programmed by wzq, 2001.06.01                        ***/
int fast_Entity_addToDb (AcDbEntity * pEntity,AcDbObjectId& id)
        AcDbDatabase *pEntityDb;
        AcDbBlockTable *pBlockTable;
        AcDbBlockTableRecord *pBlockTableRecord;
//        AcDbObjectId lineId;
//        pEntityDb = acdbCurDwg();   //ObjectARX14的形式
        pEntityDb = acdbHostApplicationServices()->workingDatabase();//ObjectARX2000的形式
        // Get the model space Block Table Record
        if(pEntityDb->getBlockTable(pBlockTable, AcDb::kForRead)!=Acad::eOk)
                return 0;
        if(pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord,
                AcDb::kForWrite)!=Acad::eOk)
                pBlockTable->close();
                return 0;
        if(pBlockTableRecord->appendAcDbEntity(id, pEntity)!=Acad::eOk)
                pBlockTableRecord->close();
                return 0;
        pEntity->close();
        return 1;
EDITION:2K
FUNCTION:fast_draw_2dpolyline
PARAMETER:起点集,突起值集
USE:绘制AcDb2dPolyline线,并加入到数据库;
RETURN:0:失败;1:成功;
AUTHOR:WANGQIN
int fast_draw_2dpolyline(AcGePoint3dArray pts,
                                                 AcGeDoubleArray blgs,
                                                 int color,
                                                 double lw,
                                                 AcDbObjectId& id)
        int ra;
        AcDb2dPolyline * p2dpl=new AcDb2dPolyline(AcDb::k2dSimplePoly,pts,
                0,Adesk::kFalse,lw,lw,&blgs);
        fast_changEntityColor(p2dpl,color);
        ra=fast_Entity_addToDb(p2dpl,id);
        //p2dpl->close();
        return ra;
Road::Road()
        g3Sp.set(0.0,0.0,0.0);
        g3Ep.set(300.0,0.0,0.0);
        dBlg=0.0;
        dWRd=32.0;
        iClrRd=3;
        idMiddle=0;
        idLift=0;
        idRight=0;
Road::Road(AcGePoint3d g3StartPt,AcGePoint3d g3EndPt,
                   int iRoadColor,
        acutPrintf("\n执行构造函数2");
        g3Sp=g3StartPt;
        g3Ep=g3EndPt;
        dBlg=dBulge;
        dWRd=dWidthRoad;
        iClrRd=iRoadColor;
        idMiddle=0;
        idLift=0;
        idRight=0;
Road::~Road()
        acutPrintf("\n执行析构函数");
void Road::drawRoad()
        int iRz;
        AcGeVector3d v3S2E=(g3Ep-g3Sp).normalize();//起点指向终点的单位矢量
        AcGePoint3d g3SpLift,g3EpLift,g3SpRight,g3EpRight;//左边线和右边线的起点和终点
        AcGePoint3dArray pts;
        AcGeDoubleArray dBlgs;
        //绘制中线
        pts.append(g3Sp);
        pts.append(g3Ep);
        dBlgs.append(dBlg);
        dBlgs.append(0);
        iRz=fast_draw_2dpolyline(pts,dBlgs,iClrRd,0,idMiddle);
        if(iRz==0)
                return ;
        pts.setLogicalLength(0);
        dBlgs.setLogicalLength(0);
        AcGeVector3d v3Tem1=v3S2E,v3Tem2=v3S2E;
        //绘制边线1
        g3SpLift=g3Sp+v3Tem1.perpVector()*dWRd;
        g3EpLift=g3Ep+v3Tem1.perpVector()*dWRd;
        pts.append(g3SpLift);
        pts.append(g3EpLift);
        dBlgs.append(dBlg);
        dBlgs.append(0);
        iRz=fast_draw_2dpolyline(pts,dBlgs,iClrRd,0,idLift);
        if(iRz==0)
                return ;
        //绘制边线2
        g3SpRight=g3Sp-v3Tem2.perpVector()*dWRd;
        g3EpRight=g3Ep-v3Tem2.perpVector()*dWRd;
        pts.append(g3SpRight);
        pts.append(g3EpRight);
        dBlgs.append(dBlg);
        dBlgs.append(0);
        if(iRz==0)
                return ;
发表于 2002-4-29 10:28:00 | 显示全部楼层
可能是别的地方有问题
我试了一下,可以运行,当然你的代码是有些问题,比如说int fast_Entity_addToDb (AcDbEntity * pEntity,AcDbObjectId& id)
对pEntity的关闭处理得不好,AcDbEntity*同你调用的地方不统一;
另外,在AutoCAD里这不叫自定义类。
 楼主| 发表于 2002-4-29 11:29:00 | 显示全部楼层
还有问题:
1、我绘制的的3条线的图形,用另存为命令,重新打开后,却没有图形。我想保存,该怎么办
2、在AutoCAD中,这不叫自定义类,应该叫什么
发表于 2002-4-30 10:54:00 | 显示全部楼层
自定义类
1、在AutoCAD中自定义类,除了C++概念外,另外一个意义是由自定义类产生的实体能被CAD所认识,也就是说,AutoCAD将不再把你的图形当线条处理,而是当公路来处理。
2、不能另存不是这段代码的问题。
GMT+8, 2025-10-6 05:29 , Processed in 0.169071 second(s), 23 queries , Gzip On.
