查看: 1246|回复: 1
请教一个问题
发表于 2006-6-17 10:48:00 | 显示全部楼层 |阅读模式
请教各位:getEntity是拾取实体,能用来拾取线吗?如果不能,需要用什么命令呀?谢谢!!
发表于 2006-6-21 20:06:00 | 显示全部楼层
All Drawing Objects
All of these objects can be defined as an AcadEntity object.
MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_3dface_object.htm" target="_blank" >3DFace   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_3dpoly_object.htm" target="_blank" >3DPolyline   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_3dsolid_object.htm" target="_blank" >3DSolid
MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_arc_object.htm" target="_blank" >Arc   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_attribute_object.htm" target="_blank" >Attribute   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_attributeref_object.htm" target="_blank" >AttributeReference
MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_blockref_object.htm" target="_blank" >BlockRef   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_circle_object.htm" target="_blank" >Circle   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_dim3pointangular_object.htm" target="_blank" >Dim3PointAngular
MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_dimaligned_object.htm" target="_blank" >DimAligned   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_dimangular_object.htm" target="_blank" >DimAngular   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_dimdiametric_object.htm" target="_blank" >DimDiametric
MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_dimordinate_object.htm" target="_blank" >DimOrdinate   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_dimradial_object.htm" target="_blank" >DimRadial   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_dimrotated_object.htm" target="_blank" >DimRotated
MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_ellipse_object.htm" target="_blank" >Ellipse   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_externalreference_object.htm" target="_blank" >ExternalReference   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_hatch_object.htm" target="_blank" >Hatch
MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_leader_object.htm" target="_blank" >Leader   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_lightweightpolyline_object.htm" target="_blank" >LightweightPolyline   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_line_object.htm" target="_blank" >Line
MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_minsertblock_object.htm" target="_blank" >MInsertBlock   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_mline_object.htm" target="_blank" >MLine   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_mtext_object.htm" target="_blank" >MText
MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_point_object.htm" target="_blank" >Point   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_polyfacemesh_object.htm" target="_blank" >PolyfaceMesh   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_polygonmesh_object.htm" target="_blank" >PolygonMesh
MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_polyline_object.htm" target="_blank" >Polyline   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_pviewport_object.htm" target="_blank" >PViewport   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_raster_object.htm" target="_blank" >Raster
MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_ray_object.htm" target="_blank" >Ray   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_region_object.htm" target="_blank" >Region   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_shape_object.htm" target="_blank" >Shape
MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_solid_object.htm" target="_blank" >Solid   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_spline_object.htm" target="_blank" >Spline   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_text_object.htm" target="_blank" >Text
MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_tolerance_object.htm" target="_blank" >Tolerance   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_trace_object.htm" target="_blank" >Trace   MSITStore:D:\Program%20Files\AutoCAD%202004\help\acadauto.chm::/idh_xline_object.htm" target="_blank" >XLine
这里面似乎就有你要的东西。这些是帮助里的内容。要学会看帮助。
GMT+8, 2025-2-21 03:41 , Processed in 0.141016 second(s), 23 queries , Gzip On.
