查看: 2005|回复: 2
[求助]求空间两曲线交点
发表于 2006-6-20 10:36:00 | 显示全部楼层 |阅读模式
搜索了好几天,没找到求空间两曲线交点的lisp程序呢!
哪位大侠提供一个?
发表于 2012-5-11 22:51:36 | 显示全部楼层
在地形图上截断面lisp
来源: http://www.znch.net/showcourse.asp?id=61
;;功能:在地形图上截断面
;;命令:dm
;;说明:
(vl-load-com)
(defun C:DM (/ M_OBJ1 M_ENT1 M_ENT2 M_JDTAB100)
    (princ "\n请选择地形线:  ")
    (setq
NUMBER
    (getint
        " 0=样条曲线; 1=多段线;2=样条曲线和多段线<默认0>:"
    (cond
((= NUMBER 0) (setq SS (ssget '((0 . "SPLINE")))))
((= NUMBER 1) (setq SS (ssget '((0 . "*POLYLINE")))))
((= NUMBER 2) (setq SS (ssget '((0 . "*POLYLINE,SPLINE")))))
(t (setq SS (ssget '((0 . "SPLINE")))))
    (if (and SS
      (setq OBJ_0 (entsel "\n请选择剖面线: "))
      (= (cdr (assoc 0 (entget (car OBJ_0)))) "LINE") ;_目前只支持直线段
     ;;转化对象类型
     (setq OBJ_0 (vlax-ename->vla-object (car OBJ_0)))
     ;;获取交点
     (setq LST_PT '()
    I 0
     (repeat (sslength SS)
  (setq OBJ_1  (vlax-ename->vla-object (ssname SS I))
        TMP    (ZL-GETINTERS OBJ_0 OBJ_1 0 "F2" NIL)
        LST_PT (append TMP LST_PT)
  (setq I (1+ I))
     ;; 排序
     ;; 点表按照xyz从小到大排序
     (setq LST_PT (vl-sort LST_PT
      '(lambda (P1 P2)
           (< (cadr P1) (cadr P2))
      '(lambda (P1 P2)
           (< (car P1) (car P2))
     ;;绘制
     (command "_.3dpoly")
     (foreach PT LST_PT
  (command "non" PT)
     (command "")
     ;;显示
     (foreach PT LST_PT
  (princ PT)
     (princ "程序完毕")
      通用函数        ;
功能:求两个线条对象的交点                                                    ;
      适用对象: Line、Circle、Arc、Ellipse、Polyline、                        ;
      LWPolyline、3dPolyline、Spline                                          ;
参数:OBJ1   ----对象1                                                        ;
      OBJ2   ----对象2                                                        ;
      Extend ----延伸选项                                                     ;
                 0  acExtendNone                                              ;
                 1  acExtendThisEntity                                        ;
                 2  acExtendOtherEntity                                       ;
                 3  acExtendBoth                                              ;
      ZZZ    ----输出选项                                                     ;
                 "=0"  Z值取0                                                 ;
                 "F1"  取第一个对象上的点                                     ;
                 "F2"  取第二个对象上的点                                     ;
                 "MAX" 取Z值大者                                              ;
                 "MIN" 取Z值小者                                              ;
      Fuzz   ----允许偏差值                                                   ;
返回:若成功,返回点位表;否则返回nil
日期:zml84 于2007-11-05
(vl-load-com)
(defun ZL-GETINTERS (OBJ1   OBJ2   EXTEND ZZZ  FUZZ /      ENT1
       ENT2   PT10   PT11   PT20  PT21 OBJ11  OBJ22
       ARRAY  LST    LST_PT I  PT PT1    PT2
       Z1     Z2
    ;;0、对参数的格式化处理
    (if (and (= (type EXTEND) 'INT)
      (<= 0 EXTEND 3)
(setq EXTEND 0)
    (setq ZZZ (strcase ZZZ))
    ;;1、获取交点集合>>>>>>>
    (if (and (= (vla-get-objectname OBJ1) "AcDbLine")
      (= (vla-get-objectname OBJ2) "AcDbLine")
;;对直线对象(line) 特别处理
     (setq ENT1 (entget (vlax-vla-object->ename OBJ1))
    ENT2 (entget (vlax-vla-object->ename OBJ2))
     (setq PT10 (assoc 10 ENT1)
    PT11 (assoc 11 ENT1)
    PT20 (assoc 10 ENT2)
    PT21 (assoc 11 ENT2)
     ;;去除Z坐标
     (setq PT10 (list (cadr PT10) (caddr PT10))
    PT11 (list (cadr PT11) (caddr PT11))
    PT20 (list (cadr PT20) (caddr PT20))
    PT21 (list (cadr PT21) (caddr PT21))
     (setq LST (inters PT10 PT11 PT20 PT21 t))
     (if LST
  (setq LST (append LST '(0)))
     ;;复制实体
     (setq OBJ11 (vla-copy OBJ1)
    OBJ22 (vla-copy OBJ2)
     ;;向xy平面投影,将Z坐标改为0
     (TOXY OBJ11)
     (TOXY OBJ22)
     ;;获取交点集合
     (setq ARRAY (vla-intersectwith OBJ11 OBJ22 EXTEND))
     ;;删除复制后的对象
     (vla-delete OBJ11)
     (vla-delete OBJ22)
     ;;由数组转换为表
     (if (and ARRAY
       (> (vlax-safearray-get-u-bound
       (vlax-variant-value ARRAY)
       1
   1
      (setq LST (vlax-safearray->list
    ;;2、分析整理>>>>>>>
    (setq LST_PT '())
    (if LST
     (setq I 0)
     (repeat (/ (length LST) 3)
  ;;2.1 获取当前点位
  (setq PT (list (nth I LST)
          (nth (+ 1 I) LST)
          (nth (+ 2 I) LST)
  ;;2.2 获取对象上对应点位
  (setq PT1 (vlax-curve-getclosestpointtoprojection
         OBJ1
         PT
         '(0 0 1)
        PT2 (vlax-curve-getclosestpointtoprojection
         OBJ2
         PT
         '(0 0 1)
  (setq Z1 (caddr PT1)
        Z2 (caddr PT2)
  ;;2.3 效验偏差值
  ;;就是说:过滤:参数中有偏差值选项,却不满足要求的点位
  (if (and FUZZ
    (or (= (type FUZZ) 'REAL)
        (= (type FUZZ) 'INT)
    (not (equal Z1 Z2 FUZZ))
      ;; 空处理
      ;;2.4 对输出选项的处理
   (cond
       ((= ZZZ "F1")
        (setq PT PT1)
       ((= ZZZ "F2")
        (setq PT PT2)
       ((= ZZZ "MAX")
        (if (> Z1 Z2)
     (setq PT PT1)
     (setq PT PT2)
       ((= ZZZ "MIN")
        (if (< Z1 Z2)
     (setq PT PT1)
     (setq PT PT2)
       (t
        (setq PT PT)
   ) ;_结束cond
   (if (member PT LST_PT)
       (setq LST_PT (cons PT LST_PT))
      ) ;_结束progn
  ) ;_结束if
  (setq I (+ I 3))
     ) ;_结束repeat
) ;_结束progn
    ) ;_结束if
    ;;3、返回结果>>>>>
    LST_PT
) ;_结束defun
;;;功能:曲线实体上每个控制点的z坐标值置为0.0
(defun TOXY (OBJ / NAME PT1 TP2)
    ;;取得实体的类型名称
    (setq NAME (vla-get-objectname OBJ))
    (cond
;;类型1
;;直线(line)
((= NAME "AcDbLine")
  ;;取得直线的起终点坐标
  (setq PT1 (vlax-variant-value (vla-get-startpoint OBJ))
        PT2 (vlax-variant-value (vla-get-endpoint OBJ))
  ;;改变z值为0.0
  (vlax-safearray-put-element PT1 2 0.0)
  (vlax-safearray-put-element PT2 2 0.0)
  (vla-put-startpoint OBJ PT1)
  (vla-put-endpoint OBJ PT2)
;;类型2
;;圆(circle)
;;圆弧(arc)
;;椭圆及椭圆弧(ellipse)
((or (= NAME "AcDbCircle")
      (= NAME "AcDbArc")
      (= NAME "AcDbEllipse")
  ;;取得中心点座标
  (setq PT1 (vlax-variant-value (vla-get-center OBJ)))
  ;;改变中心点座标z值为0.0
  (vla-put-center OBJ PT1)
;;类型3
;;多段线(polyline、lwpolyline)
;;拟合的2维多段线(polyline、lwpolyline)
((or (= NAME "AcDbPolyline")
      (= NAME "AcDb2dPolyline")
  ;;改变标高值为0.0
  (vla-put-elevation OBJ 0.0)
;;类型4
;;三维多段线(3dpolyline)
((= NAME "AcDb3dPolyline")
  ;;取得3维多段线的控制点
  (setq PT1 (vlax-variant-value (vla-get-coordinates OBJ))
        I   0
  (repeat (/ (length (vlax-safearray->list PT1)) 3)
      (vlax-safearray-put-element PT1 (+ I 2) 0.0)
      (setq I (+ I 3))
  (vla-put-coordinates OBJ PT1)
;;类型5
;;样条曲线(Spline)
((= NAME "AcDbSpline")
  ;;取得样条曲线的拟合点
  ;;改变每个拟合点的z值为0.0
  (setq PT1 (vlax-variant-value (vla-get-fitpoints OBJ))
        I   0
  (repeat (vla-get-numberoffitpoints OBJ)
      (setq I (+ I 3))
  (vla-put-fitpoints OBJ PT1)
  ;;取得样条曲线的控制点
  ;;改变每个控制点的z值为0.0
  (setq
      PT2 (vlax-variant-value (vla-get-controlpoints OBJ))
      I  0
  (repeat (vla-get-numberofcontrolpoints OBJ)
      (vlax-safearray-put-element PT2 (+ I 2) 0.0)
      (setq I (+ I 3))
  (vla-put-controlpoints OBJ PT2)
(t NIL)
) ;_结束defun
本文来自: <a href=http://www.znch.net>[中南测绘信息中心]</a> 详细出处参考:<a href=http://www.znch.net/showcourse.asp?id=61>http://www.znch.net/showcourse.asp?id=61</a>
发表于 2013-4-6 10:44:23 | 显示全部楼层
太谢谢楼主了,我正需要这个呢。
GMT+8, 2025-7-20 09:12 , Processed in 0.162675 second(s), 25 queries , Gzip On.
