查看: 2003|回复: 1
請教ACDBPOLYLINE在OFFSET時.它的方向和那些因素有關.比如上下還是左右.
发表于 2003-3-11 15:09:00 | 显示全部楼层 |阅读模式
11111111
发表于 2003-3-12 13:33:00 | 显示全部楼层
1) The direction is determined by the ECS and vertexes of this polyline.
2) You don't need to know the direction first. You only need to perform a time of offset and then compare some data (fg. the area ). Then you can get the direction.
3)By the way, the sysvalue "offsetgaptype" must be controled.
GMT+8, 2025-4-5 05:26 , Processed in 0.139001 second(s), 24 queries , Gzip On.
