查看: 1830|回复: 4
[求助]计算选择集中某个字符个数的问题:
发表于 2006-7-2 09:45:00 | 显示全部楼层 |阅读模式
计算选择集中某个字符个数的问题:
以下是我的代码:
Public Sub count()
    On Error Resume Next
   Dim objtext As AcadText
    Dim height As Double
    Dim width As Double
    Dim SSet As AcadSelectionSet
    If Not IsNull(ThisDrawing.SelectionSets.Item("this")) Then
        Set SSet = ThisDrawing.SelectionSets.Item("this")
        SSet.Delete
    End If
    Set SSet = ThisDrawing.SelectionSets.Add("this")
    Dim filterType(0) As Integer
    Dim filterData(0) As Variant
    filterType(0) = 0
    filterData(0) = "Text"
    SSet.SelectOnScreen filterType, filterData
    Dim pt1(0 To 2) As Double
    Dim pt2(0 To 2) As Double
    pt1(0) = 0: pt1(1) = 0: pt1(2) = 0
     pt2(0) = 0: pt2(1) = 180: pt2(2) = 0
     Dim n As Integer
     n = 0
    For Each objtext In SSet
    If objtext.TextString = "T" Then n = n + 1
   AddLine pt1, pt2
    MsgBox "一共有" & n & "个字符", vbOKOnly
  EXIT FOR
    Next
End Sub
运行得到的结果却与想象中的相差较远,
我本想输出选择集中“T”的数量,(例如T是选择集中任一字符),而输出结果为0,
请问上面的函数该如何修正?
是否要用LEN函数来统计字符数量?
发表于 2006-7-2 11:03:00 | 显示全部楼层
你是想只查找“T”,还是包含“T”的
“aT”这样的要计算在内么?
 楼主| 发表于 2006-7-2 17:43:00 | 显示全部楼层
我只查“T”,而且文字是单独出现在图档中的单个文字 ,不需要“AT”这样的!当然图档中还有另外的单个文字要统计,比如还有“R”,“X”等!
发表于 2006-7-2 18:58:00 | 显示全部楼层
  1. Public Sub count()
  2.     On Error Resume Next
  3.
  4.     Dim SSet As AcadSelectionSet
  5.     ThisDrawing.SelectionSets("this").Delete
  6.     Set SSet = ThisDrawing.SelectionSets.Add("this")
  7.
  8.     Dim filterType(1) As Integer
  9.     Dim filterData(1) As Variant
  10.     filterType(0) = 0
  11.     filterData(0) = "Text"
  12.     filterType(1) = 1
  13.     filterData(1) = "T"
  14.
  15.     SSet.SelectOnScreen filterType, filterData
  16.
  17.     MsgBox "一共有" & SSet.count & "个字符", vbOKOnly
  18. End Sub
 楼主| 发表于 2006-7-3 09:01:00 | 显示全部楼层
谢谢,如果另外的单个文字要统计,比如还有“R”,“X”,该如改上面的代码?
GMT+8, 2025-5-4 09:46 , Processed in 0.174799 second(s), 23 queries , Gzip On.
