- 积分
- 24616
- 明经币
- 个
- 注册时间
- 2004-3-17
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
 - Sub jline()
- Dim obj As AcadLine, pnt
- Dim objs As New Collection
- Dim selobj As AcadLine
- Dim pnts As New Collection
- Dim i, j
- ThisDrawing.Utility.GetEntity obj, pnt
- Dim ss As New TlsSelectionSet
- pnts.Add obj.StartPoint
- pnts.Add obj.EndPoint
- objs.Add obj
- '从选择线起点找起,一直到没有连接的直线或一个以上的直线为止
- Do While True
- ss.Init
- ss.Filter.SetData 0, "line", -4, "<or", 10, pnts(1), 11, pnts(1), -4, "or>"
- ss.SelectObject acSelectionSetAll
- If ss.Count = 2 Then
- If ss.Item(0) Is obj Then
- Set obj = ss.Item(1)
- Else
- Set obj = ss.Item(0)
- End If
- If isChild(objs, obj) Then Exit Do
- If obj.StartPoint(0) = pnts(1)(0) And obj.StartPoint(1) = pnts(1)(1) Then
- pnts.Add obj.EndPoint, , 1
- Else
- pnts.Add obj.StartPoint, , 1
- End If
- objs.Add obj, , 1
- Else
- Exit Do
- End If
- Loop
- '从选择线终点找起,一直到没有连接的直线或一个以上的直线为止
- Set obj = selobj
- Do While True
- ss.Init
- ss.Filter.SetData 0, "line", -4, "<or", 10, pnts(pnts.Count), 11, pnts(pnts.Count), -4, "or>"
- Else
- End If
- If obj.StartPoint(0) = pnts(pnts.Count)(0) And obj.StartPoint(1) = pnts(pnts.Count)(1) Then
- Else
- End If
- objs.Add obj
- Else
- Exit Do
- End If
- Loop
- Dim dots() As Double
- ReDim dots(pnts.Count * 2 - 1)
- For i = 1 To pnts.Count
- For j = 0 To 1
- dots((i - 1) * 2 + j) = pnts(i)(j)
- Next
- Next
- ThisDrawing.ModelSpace.AddLightWeightPolyline dots
- For Each i In objs
- i.Delete
- Next i
- End Sub
- Function isChild(objs As Variant, obj As Object)
- Dim i
- If i Is obj Then isChild = True: Exit For
- Next
- End Function
